Home » Eclipse Projects » GEF » coping with gradients and ScaledGraphics ?
coping with gradients and ScaledGraphics ? [message #243422] Fri, 06 June 2008 13:58 Go to next message
Originally posted by: max.andersen.redhat.com
Hi guys,
I'm having "fun" with Gef and doing some nice gradients with
setBackgroundPattern() - all looking nice and pretty...
Just until I start using the outline view which uses a ScaledGraphics to
give an "overview" map and getting exceptions
because ScaledGraphics does not support backgroundPattern.
I solved it currently by doing an instanceof check in paintfigure to avoid
the backgroundpattern in the outline view.
Is that really the only way around this ? Is there a "better"
scaledGraphics implementation somewhere ?
I'm also worried what happens when I start printing etc. ?
/max
Re: coping with gradients and ScaledGraphics ? [message #243477 is a reply to message #243422] Mon, 09 June 2008 11:22 Go to previous messageGo to next message
Hi Max,
I am not totally familiar with the history behind ScaledGraphics, but a
number of these SWT features do not scale so are not supported by
ScaledGraphics.
I have a question for you though.
You are able to show a gradient in your editor, do you have support to scale
your editor (zoom)? Are you using SWTGraphics?
Can you raise a Bugzilla for this? Not sure if there is one already.
Cheers...
Anthony
"Max Rydahl Andersen" <max.andersen@redhat.com> wrote in message
news:op.ucb9jvemw1tq5a@reddevil...
> Hi guys,
> /max
Re: coping with gradients and ScaledGraphics ? [message #243535 is a reply to message #243477] Wed, 11 June 2008 09:44 Go to previous messageGo to next message
> ScaledGraphics.
yes, but an approximation would be good ;)
> scale
We use a org.eclipse.draw2d.parts.Thumbnail (which in turn uses a
ScaledGraphics) to show a "birds-view" map of the graph
in the outline view which the user can use to quickly navigate somewhere
else.
Do you know any better way ?
Will do.
/max
> Cheers...
> Anthony
>> Hi guys,
>> avoid
>> /max
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: coping with gradients and ScaledGraphics ? [message #243539 is a reply to message #243535] Wed, 11 June 2008 09:47 Go to previous message
There were an existing bug for this (albeit with a bad title):
https://bugs.eclipse.org/bugs/show_bug.cgi?id=184651
/max
>> ScaledGraphics.
>> scale
> else.
> Will do.
> /max
>> Cheers...
>> Anthony
>>> Hi guys,
>>> to
>>> avoid
>>> /max
Previous Topic:Eception in object creation
Next Topic:Showing GEF editor on a SWT composite
Current Time: Sat Nov 08 18:38:54 EST 2025
Powered by FUDForum. Page generated in 0.03361 seconds
