Home » Eclipse Projects » GEF » Make part of Label editable?
Make part of Label editable? [message #23912] Fri, 04 October 2002 19:40 Go to next message
I am trying to make part of the Label editable, for example, I have a label
with text "[only editable part]" but only text within [] is editable.
So in my LabelEditManager I strip the "[" and "]" when i initialize teh cell
editor. It does display the text which are editable.
But how can I surround the text that user put with "[]"?
There are 2 cases need to consider:
- user clicks the label, cell editor pops up, and he enters a new value
- user clicks the label, cell editor pops up, he clicks something else, so
he never change the value of the label
How i inital the cell editor:
String labelText =
((Label)((GraphicalEditPart)getEditPart()).getFigure()).getT ext();
getCellEditor().setValue(labelText.substring(1, labelText.length - 1));
Another approach I can think of is have 1 non-editable label for "[" , 1
non-editable label for "]" and 1 editable labe for the editable part. But I
am trying to reduce the number of objects as much as I can.
Thanks in advance for any help.
Re: Make part of Label editable? [message #24058 is a reply to message #23912] Sat, 05 October 2002 01:36 Go to previous messageGo to next message
If you're already stripping out the brackets when you initialize the cell
editor, you can change LabelDirectEditPolicy.getDirectEditCommand(...) so that
it creates a new LogicLabelCommand with the brackets surrounding the text.
protected Command getDirectEditCommand(DirectEditRequest edit) {
String labelText = (String)edit.getCellEditor().getValue();
LogicLabelEditPart label = (LogicLabelEditPart)getHost();
LogicLabelCommand command = new
LogicLabelCommand((LogicLabel)label.getModel(), "["+labelText+"]");
return command;
Eric
Hal wrote:
> String labelText =
Re: Make part of Label editable? [message #24157 is a reply to message #23912] Sat, 05 October 2002 16:38 Go to previous message
Originally posted by: hudsonr.us.eye-bee-em.com
Text control has a validateEdit callback. There is a way to prevent the
user from editing parts of the Text, but I think that sounds real strange.
Just surround the text with brackets when you display it in the label
figure, and everywhere else there are no brakets
"Hal" <otaconss2@hotmail.com> wrote in message
news:anl7it$v84$1@rogue.oti.com...
label
cell
> String labelText =
I
Previous Topic:Free UML modelor for Eclipse
Next Topic:Make Label in LogicEditor example resizble
Current Time: Sat Sep 13 15:19:03 EDT 2025
Powered by FUDForum. Page generated in 0.04797 seconds
