Home » Eclipse Projects » GEF » Problems with GEF diagram editor in a ViewPart
Problems with GEF diagram editor in a ViewPart [message #243410] Thu, 05 June 2008 22:45 Go to next message
Hello.
I am pretty new to GEF and having some problems implementing a diagram
editor based on GEF inside a view.
I looked at the Digraph1 example and found out that it uses a
ScrollingGraphicalViewer inside the ViewPart. Can this implementation be
extended to the same degree as a GraphicalEditor (like drag, resize, add
items)?
One drawback I already see is that the GraphicalViewer doesn't seem to
have a palette (like GraphicalEditorWithPalette). Is it possible to have
tools like "SelectionToolEntry" or "MarqueeToolEntry" as actions in a
toolbar instead as tools in the palette? Is there an easy way to
accomplish this?
Kai
Re: Problems with GEF diagram editor in a ViewPart [message #243467 is a reply to message #243410] Mon, 09 June 2008 11:16 Go to previous message
Hi Kai
Not sure I understand why your view would be editable with these features,
sounds more like you have an editor.
If this is a view, what is the content of your active editor when your GEF
view is open?
Cheers...
Anthony
"Kai Schlamp" <schlamp@gmx.de> wrote in message
news:72207094953b327cf7b5dc5206d73fe6$1@www.eclipse.org...
> Hello.
> items)?
> accomplish this?
> Best regards,
> Kai
Previous Topic:Copy GEF diagram as WMF?
Next Topic:[Announce] GEF 3.4.0RC4 is available
Current Time: Tue Nov 04 14:20:20 EST 2025
Powered by FUDForum. Page generated in 0.24123 seconds
