Home » Eclipse Projects » Nebula » Grid Widget
Grid Widget [message #23907] Mon, 22 January 2007 15:10 Go to next message
I'm thinking about using the Nebula Grid Widget in a project, but I plan to
use only the header. So my questions:
a) is it possible to set column alignment in the header (ex: using a two
lines header, I want to center both in width & height)?
b) is it possible to show only the header (like in Table.setLinesVisible =
false)?
c) is it possible to have a custom height for the header?
Re: Grid Widget [message #24331 is a reply to message #23907] Wed, 24 January 2007 17:47 Go to previous message
Hi Anibal,
a.) This is only possible if you write your own renderer for the grid
header.
b.) Use Grid#setLinesVisible?
c.) Just like a, only if you write your own renderer for the header.
-Chris
> false)?
> Thanks
Re: Grid Widget [message #575653 is a reply to message #23907] Wed, 24 January 2007 17:47 Go to previous message
Hi Anibal,
header.
-Chris
> false)?
> Thanks
Previous Topic:Non-editable Grid columns?
Next Topic:New Nebula Presentation Component...
Current Time: Tue Jul 22 02:28:07 EDT 2025
Powered by FUDForum. Page generated in 0.04968 seconds
