Home » Archived » BIRT » duplicate colors in pie charts
duplicate colors in pie charts [message #243386] Tue, 19 June 2007 14:22 Go to next message
Originally posted by: rbhardwaj.tier.com
I am trying to generate pie charts using birt, it seems that whenever the
number of columns is more than 4-5 (not even 8), the pie chart has sectors
of duplicate colors.
I have tried it on birt 2.1.2 and 2.2.1 rc 3.
Am I doing something wrong? Is there any workaround for this?
Rahul
Re: duplicate colors in pie charts [message #243518 is a reply to message #243386] Wed, 20 June 2007 09:39 Go to previous messageGo to next message
Did you trie to add some colors?
"Rahul Bhardwaj" <rbhardwaj@tier.com> schrieb im Newsbeitrag
news:f596u1$o23$1@build.eclipse.org...
> Thanks
> Rahul
Re: duplicate colors in pie charts [message #243548 is a reply to message #243518] Wed, 20 June 2007 10:09 Go to previous messageGo to next message
Yes, i did add quite a few colors. I even tried removing all colors and then
add complete new set of colors. I could see the new colors being used but
every sector after column 5 was colored using the same color.
Can you confirm that you have seen unique colors in use especially when the
number of sectors is more than 8? If yes, can you tell me the BIRT version
that you used?
"Peter Hoffmann" <petepack@gmx.de> wrote in message
news:f5baq2$1s4$1@build.eclipse.org...
>> Thanks
>> Rahul
Re: duplicate colors in pie charts [message #243587 is a reply to message #243548] Wed, 20 June 2007 11:12 Go to previous messageGo to next message
Look at the topic
Bar Chart SeriesPallete (Color) isnt acting as it should
writtten by myself the 13.06.2007
I was complaining about that I had the problems like you:
The funny thing was: I was just editing the colors of the wrong axis. So I
got it to work with +24 colors.
Edit:
Well, damn. I have to learn to read before post: You are using Pie charts.
Ill try it for you, and post back, if its working.
Btw: Using Birt 2.1.
news:f5bchc$cof$1@build.eclipse.org...
> then add complete new set of colors. I could see the new colors being used
> but every sector after column 5 was colored using the same color.
> the number of sectors is more than 8? If yes, can you tell me the BIRT
> version that you used?
>>>sectors of duplicate colors.
>>> Thanks
>>> Rahul
Re: duplicate colors in pie charts [message #243838 is a reply to message #243548] Thu, 21 June 2007 07:47 Go to previous message
It is likely you are adding colors to the wrong palette. If you color by
category (which is the case here), you need to add colors in the category
palette, not the series palette.
David
"Rahul Bhardwaj" <rbhardwaj@tier.com> wrote in message
>>> Thanks
>>> Rahul
Previous Topic:[2.2RC3] .Problem in multithreadding
Next Topic:Problems setting Y-Axis min and max dynamically
Current Time: Thu Jul 03 14:58:40 EDT 2025
Powered by FUDForum. Page generated in 0.04265 seconds
