Home » Language IDEs » ServerTools (WTP) » Using "${}"
Using "${}" [message #23899] Thu, 20 May 2004 11:47 Go to next message
Originally posted by: bbozek.email.hinet.hr
When I'm using display tag "<display:table name="${users.rows}" id="user"
class="list">"
result is empty table (Nothing found to display.).
With following code everything looks fine.
"<display:table name="pageScope.expanses.rows" id="rows" class="list">"
I still can't get rows from table using "value="<c:out
value="${user.firstName}"/>" ".
How I can retrieve "users" using ${user.username} expression.
CODE EXAMPLE
<sql:query var="users" >
select id, username, firstName, lastName
from temp_user order by upper(username)
</sql:query>
<display:table name="${users.rows}" id="user" class="list">
<display:column title="Username">
<input type="text" name="username" style="padding: 0"
value="<c:out value="${user.username}"/>" />
</display:column>
</display:table>
Result for "value="<c:out value="${user.username}" is "${user.username}".
Probably I forget to set something on my JSP page or in web.xml file.
I have spend few day to find solution.
Hope that somebody can help me.
Thanks!
Branko
Re: Using "${}" [message #23982 is a reply to message #23899] Thu, 20 May 2004 15:39 Go to previous messageGo to next message
Originally posted by: sean_dynan.nowhere.com
BBozek wrote:
<snip/>
First things first...the 'display', 'sql' and 'c' taglibs you are using:
are they Expression Language versions? In other words, does this work
as you would expect?
value="<%=user.getUsername();%>"
If it does, that would suggest that your c.tld taglib *isn't* an EL
version. Ditto for your 'display' taglib.
Sean Dynan
Re: Using "${}" [message #24106 is a reply to message #23982] Fri, 21 May 2004 07:49 Go to previous messageGo to next message
Code value="<%=user.getUsername();%>" doesn't work.
How I can recognize c.tld taglib EL version?
Branko
"Sean Dynan" <sean_dynan@nowhere.com> wrote in message
news:c8j13b$2cg$1@eclipse.org...
> BBozek wrote:
> <snip/>
"${user.username}".
> Sean Dynan
Re: Using "${}" [message #24119 is a reply to message #24106] Fri, 21 May 2004 10:28 Go to previous messageGo to next message
(whoops...that semi-colon shouldn't be there)
I use the Apache taglibs. The c.tld descriptor is the EL version,
c-rt.tld is not. And inside the c.tld file the 'out' tag's Java class
is 'org.apache.taglibs.standard.tag.el.core.OutTag', whereas the
c-rt.tld tag is 'org.apache.taglibs.standard.tag.rt.core.OutTag'.
Are you importing the TLD properly in your JSP?
Something like this in your JSP:
<%@ taglib uri="/WEB-INF/c.tld" prefix="c" %>
Sean
Re: Using "${}" [message #24222 is a reply to message #24119] Fri, 21 May 2004 11:53 Go to previous messageGo to next message
I am using EL version properly.
I doesn't have "listener" in my application.
Maybe problem is there.
Branko
news:c8l37o$k47$1@eclipse.org...
> Sean
Re: Using "${}" [message #24263 is a reply to message #24222] Fri, 21 May 2004 14:19 Go to previous messageGo to next message
What's a "listener" ?
Sean
Re: Using "${}" [message #24924 is a reply to message #24263] Mon, 24 May 2004 04:43 Go to previous message
I saw in web.xml something like this.
<listener>
<listener-class>org.apache.taglibs.standard.examples.startup.Init </listener-
class>
</listener>
Examples I have work fine with ${user.username} expression when they have
above deployment descriptor and class.
Problem can be in <sql:query>. It retrieve table not object.
Branko
news:c8lgqb$7vn$1@eclipse.org...
> Sean
Previous Topic:[ANN] MyEclipse 2.8 Beta Release - New RAD Tooling
Next Topic:Lomboz and Licensing question
Current Time: Sat Jul 26 05:10:53 EDT 2025
Powered by FUDForum. Page generated in 0.03980 seconds
