| Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » java.lang.CircularityError IClientSelector
 Goto Forum:|
| java.lang.CircularityError IClientSelector [message #23894] | Mon, 20 February 2006 16:10  |  |
| Eclipse User  |  |  |  |  | Originally posted by: saya.txesystems.com
 As validation framework nicely supports OCL, following the tutorial for
 validation framework in emf, I tried to implement a simple constraint with
 my two plugins GeneratedOETests and helloworld. helloworld contributes the
 context, binding and constrain in its plugin.xml:
 <extension
 point="org.eclipse.emf.validation.constraintBindings">
 <clientContext
 default="false"
 id="com.acme.orderentry.constraintsContext">
 <selector
 class="helloworld.actions.ValidationDelegateClientSelector"/ >
 </clientContext>
 <binding
 context="com.acme.orderentry.constraintsContext"
 category="com.acme.orderentry.constraints"/>
 </extension>
 <extension
 point="org.eclipse.emf.validation.constraintProviders">
 <category
 name="OrderEntry Constraints"
 id="com.acme.orderentry.constraints"/>
 <constraintProvider cache="true">
 <package namespaceUri="http:///orderentry.ecore"/>
 <constraints categories="com.acme.orderentry.constraints">
 <constraint
 lang="Java"
 class="helloworld.actions.NonEmptyNamesConstraint"
 severity="ERROR"
 mode="Batch"
 name="Non-Empty Names"
 id="com.acme.orderentry.constraints.NameNotEmpty"
 statusCode="1">
 <description>
 All customers should have some unique identifier or name.
 </description>
 <message>
 A {0} has been found to have no unique identifier (name
 or   title).
 </message>
 <target class="Customer"/>
 </constraint>
 </constraints>
 </constraintProvider>
 </extension>
 In GeneratedOETests which depend on helloworld, the plugin-test
 BatchValidator does the following:
 Customer customer=OrderEntryFactory.eINSTANCE.createCustomer();
 ValidationDelegateClientSelector.running = true;
 IBatchValidator validator =
 (IBatchValidator)ModelValidationService.getInstance()
 .newValidator(EvaluationMode.BATCH);
 validator.setIncludeLiveConstraints(true);
 IStatus status=validator.validate(customer,null);
 ValidationDelegateClientSelector.running = false;
 Collection descs=ConstraintRegistry.getInstance().getAllDescriptors();
 logger.debug("desc size:"+descs.size());
 Collection
 contexts=ClientContextManager.getInstance().getClientContext s();
 logger.debug("contexts size:"+contexts.size());
 In validator.validate(customer,null), when the class loader tries to load
 ValidationDelegateClientSelector, it gives  java.lang.CircularityError
 error. Before trying to load the ValidationDelegateClientSelector, the
 class loader actually looks at whether it has been alrady loaded and it
 fails to find the class altough we already used it before calling the
 validator.validate(customer,null) method.
 I am using eclipse 3.2.0
 I had spent quite some time on this. I would appreciate any directions or
 suggestions for workarounds.
 Selcuk
| Re: java.lang.CircularityError IClientSelector [message #23935 is a reply to message #23894] | Mon, 20 February 2006 17:51   |  |
| Eclipse User  |  |  |  |  | Hi Selcuk,
 Do you have a stack trace for the CircularityError?
 Chris McGee
 Selcuk Aya wrote:
 > with my two plugins GeneratedOETests and helloworld. helloworld
 > contributes the context, binding and constrain in its plugin.xml:
 > <extension
 >      <clientContext
 >            default="false"
 >         <selector
 >      </clientContext>
 >      <binding
 >   </extension>
 >  <extension
 >      <category
 >            <constraint
 >                  lang="Java"
 >                  severity="ERROR"
 >                  mode="Batch"
 >                  statusCode="1">
 >               <description>
 >               </description>
 >               <message>
 > or   title).
 >               </message>
 >            </constraint>
 >         </constraints>
 >   </extension>
 >         Collection
 >         Collection
 > load  ValidationDelegateClientSelector, it gives
 > java.lang.CircularityError error. Before trying to load the
 > ValidationDelegateClientSelector, the class loader actually looks at
 > whether it has been alrady loaded and it fails to find the class altough
 > we already used it before calling the validator.validate(customer,null)
 > method.
 > or suggestions for workarounds.
 > Selcuk
| Re: java.lang.CircularityError IClientSelector [message #34761 is a reply to message #24011] | Wed, 24 May 2006 00:18  |  |
| Eclipse User  |  |  |  |  | Originally posted by: brucet.nospam.com
 I have hit a very similar problem.  (I am new to Eclipse, EMF and the
 EMF Validation Framework, so sorry if I am off the mark on my analysis.)
 From looking at the stack trace and this bug
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=5875, I am guessing that
 something like the following is happening:
 1.  ValidationDelegateClientSelector resides in PluginB.  An action in
 PluginA calls the following line (which is line
 WorkingsetActionBarContributor.java:137 in the stack trace below).
 2.  During initialization of ValidationDelegateClientSelector, the osgi
 loader loads the EMFModelValidationPlugin because
 ValidationDelegateClientSelector implements
 org.eclipse.emf.validation.model.IClientSelector.
 3.  During initialization of EMFModelValidationPlugin,
 EMFModelValidationPlugin.configureConstraintBindings finds that
 ValidationDelegateClientSelector is defined in the constraint bindings,
 and so attempts to load ValidationDelegateClientSelector.
 4.  ValidationDelegateClientSelector is already being initialized from
 step 1, and so throws java.lang.ClassCircularityError.
 I have gotten around this for now by forcing EMFModelValidationPlugin to
 load before ValidationDelegateClientSelector.running is called.
 Is there something else I should be doing to avoid this problem?
 -Bruce
 java.lang.ClassCircularityError:
 org/eclipse/emf/validation/model/IClientSelector
 at java.lang.ClassLoader.defineClass1(Native Method)
 at java.lang.ClassLoader.defineClass(Unknown Source)
 org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:160)
 org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:498)
 org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:468)
 org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:427)
 org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:410)
 org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:391)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
 org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
 org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:276)
 org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
 org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
 org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
 org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
 org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
 org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
 org.eclipse.emf.validation.internal.service.ClientContext.in itializeCustomSelector(ClientContext.java:186)
 org.eclipse.emf.validation.internal.service.ClientContext.in itializeSelector(ClientContext.java:122)
 org.eclipse.emf.validation.internal.service.ClientContext.<init >(ClientContext.java:72)
 org.eclipse.emf.validation.internal.service.ClientContextMan ager.configureClientContexts(ClientContextManager.java:321)
 org.eclipse.emf.validation.internal.service.ClientContextMan ager.configureConstraintBindings(ClientContextManager.java:3 04)
 org.eclipse.emf.validation.internal.EMFModelValidationPlugin $Implementation.configureConstraintBindings(EMFModelValidati onPlugin.java:247)
 org.eclipse.emf.validation.internal.EMFModelValidationPlugin $Implementation.start(EMFModelValidationPlugin.java:220)
 org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:995)
 org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:989)
 org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
 org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
 org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
 org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
 org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
 org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:388)
 at java.lang.ClassLoader.loadClassInternal(Unknown Source)
 com.xxx.yyy.zzz.vvv.api.workingset.presentation.WorkingsetAc tionBarContributor$2.run(WorkingsetActionBarContributor.java :137)
 at  org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
 org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
 org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
 org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
 at  org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
 at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
 at  org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
 at  org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
 at  org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
 at  org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
 org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
 at  org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
 com.xxx.yyy.zzz.vvv.api.DesignerEditorAdvisor$Application.ru n(DesignerEditorAdvisor.java:109)
 org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
 org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
 org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
 org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
 org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
 at  org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
 at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
 at org.eclipse.core.launcher.Main.run(Main.java:977)
 at org.eclipse.core.launcher.Main.main(Main.java:952)
| Re: java.lang.CircularityError IClientSelector [message #568078 is a reply to message #23894] | Mon, 20 February 2006 17:51  |  |
 Chris McGee
 Selcuk Aya wrote:
 > <extension
 >      <clientContext
 >            default="false"
 >         <selector
 >      </clientContext>
 >      <binding
 >   </extension>
 >  <extension
 >      <category
 >            <constraint
 >                  lang="Java"
 >                  severity="ERROR"
 >                  mode="Batch"
 >                  statusCode="1">
 >               <description>
 >               </description>
 >               <message>
 > or   title).
 >               </message>
 >            </constraint>
 >         </constraints>
 >   </extension>
 >         Collection
 >         Collection
 > method.
 > Selcuk
| Re: java.lang.CircularityError IClientSelector [message #568108 is a reply to message #23935] | Mon, 20 February 2006 18:48  |  |
| Eclipse User  |  |  |  |  | Hi Chris, the stack trace returns null. When I debug, I actually get a
 ClassNotFoundError but when I dig in I can see that the class loader
 returns circularity error.
 One thing I tried was to remove the dependency on helloworld from
 GeneratedOETests. I made the latch ValidationDelegateClient return true
 always. This time the class loader successfully loaded the class and
 everything went fine.
 Selcuk
| Re: java.lang.CircularityError IClientSelector [message #568140 is a reply to message #23973] | Mon, 20 February 2006 20:23  |  |
 I have seen ClassCircularityError thrown in eclipse before and they were
 caused by the plugin activator class trying to load a class that is in a
 plugin that is already in the process of loading.
 We found that the best way to avoid this problem is to avoid static
 initializers in classes and avoid adding code to the start() method in
 plugin activator classes.
 In this case, I'm not seeing how the circularity could be formed because
 the ValidationDelegateClientSelector should have to be loaded prior to
 the validator.validate() call. Any chance you could set a breakpoint on
 the ClassCircularityError constructor(s) and provide the stack? Calling
 e.printStackTrace() after the error is constructed should provide the
 stack on the console.
 Chris
 Selcuk Aya wrote:
 > Hi Chris,
 > Selcuk
| Re: java.lang.CircularityError IClientSelector [message #578411 is a reply to message #24011] | Wed, 24 May 2006 00:18  |  |
 -Bruce
 Current Time: Fri Oct 31 10:36:17 EDT 2025
 Powered by FUDForum . Page generated in 0.04265 seconds |
