Home » Eclipse Projects » Eclipse Platform » NLS Support for 3.0M8
NLS Support for 3.0M8 [message #243152] Fri, 21 May 2004 10:13 Go to next message
Originally posted by: adamh.us.ibm.com
I am attempting to add NLS support for group one languages and cannot get
the language locale to change. In the PDE I am passing the parameter "-nl
de", but the "DE" language files within my fragment plugin are not being
used. I dumped the Plugin parameters (Platform.getCommandLineArgs()) and
only see "-application" and "- product" command line arguments.
Is there another way I can check the eclipse platform's running locale?
Re: NLS Support for 3.0M8 [message #243167 is a reply to message #243152] Fri, 21 May 2004 10:18 Go to previous messageGo to next message
I see there is a Platform.getNL() and it gives me "en_US". Does anyone
know of a problem with "-nl" command line argument in M8?
Re: NLS Support for 3.0M8 [message #243195 is a reply to message #243167] Fri, 21 May 2004 10:54 Go to previous message
Doh! Found the problem....I needed the locale to be de_DE
Previous Topic:deleting from cvs
Next Topic:How do I use the memory view?
Current Time: Thu Nov 27 08:37:25 EST 2025
Powered by FUDForum. Page generated in 0.03989 seconds
