Home » Eclipse Projects » Eclipse Platform » deleting from cvs
deleting from cvs [message #243109] Fri, 21 May 2004 05:38 Go to next message
Originally posted by: a.maggi.selta.it
Hi everybody,
I'm a newbie trying to get started with eclipse, and i'm
facing some problems:
1)How can i delete files from a project in the cvs ?
I tried to delete it locally and the commit the project but
it doesn't work.
2)How can i delete old version from my cvs ?
i tried right-clicking on the version -> Configuring branches
and versions -> delete but nothing happens
3) where can i find something like "eclipse beginners manual"?
Alessandro Maggi
Re: deleting from cvs [message #243115 is a reply to message #243109] Fri, 21 May 2004 08:31 Go to previous messageGo to next message
Cvs have complete project history (and deleted file) If You don't need and
want fresh cvs you can delete modul in cvs server direct and add project
again - files deleted local aren't anymore in current cvs branch, but
history is in cvs
If You want more features version control you try subversion
(subversion.tigris.org) - They have eclispe plugin, too
regards
A. wrote:
> Hi everybody,
> it doesn't work.
Re: deleting from cvs [message #243182 is a reply to message #243109] Fri, 21 May 2004 10:42 Go to previous message
Originally posted by: eclipse.rizzoweb.com
A. wrote:
> Hi everybody,
> it doesn't work.
Be more specific - what do you mean when you say "it doesn't work"? What
steps, exactly, did you follow? Deleting locally, then doing a
Synchronize on the containing directory or Project does indeed work -
I've done it many times.
CVS does not allow you to permanently remove a file from the repository
unless you log in to the CVS server and do it manually. It is rarely
necessary/desired to do so.
Open the Eclipse Help, and you'll find several Tutorials under the main
headings ("Getting Started").
HTH,
Eric
Previous Topic:Programmtically creating a project OUTSIDE the workspace
Next Topic:NLS Support for 3.0M8
Current Time: Sun Aug 31 21:06:17 EDT 2025
Powered by FUDForum. Page generated in 0.04645 seconds
