Home » Archived » BIRT » [BIRT2.2RC0 Deployment] BEA Weblogic 8.1.x
[BIRT2.2RC0 Deployment] BEA Weblogic 8.1.x [message #243091] Mon, 18 June 2007 09:43 Go to next message
Hi there,
i experienced birt during the last three month, there were a lot of downs
and also a few highlights ;)
finally my framework works quite allright on a tomcat and also on a sun
appserver...
but today after the presentation my boss decided TO CHANGE TO A BEA
WEBLOGIC PLATFORM!
i went through the newsgroups and found some known bugs using this
webserver.. and after a lot of trying a finally got my framework deployed
without getting any exceptions.
i figured out, that the following jar
org.eclipse.equinox.registry_3.3.0.v20070416.jar
causes the java.lang.StringIndexOutOfBoundsException.
so now my questions:
1. are there any experiences in working with birt2.2rc0 on a weblogic?
2. will this bug be fixed in the 2.2 release?
or:
is there no light at the end of the tunnel and so i have to persuade my
boss to use a tomcat?
greetings,
chris from munich
Re: [BIRT2.2RC0 Deployment] BEA Weblogic 8.1.x [message #243190 is a reply to message #243091] Mon, 18 June 2007 18:12 Go to previous messageGo to next message
Chris,
Can you post the stacktrace? Also have you tried this with RC2 or 3?
Please log a bugzilla entry as well.
BTW, I would be interested in understanding where you found pain points
in using BIRT. We are beginning post 2.2 planning and anything we can
do to make the BIRT experience more pleasant is worth considering.
Jason
chris wrote:
> Hi there,
> downs and also a few highlights ;)
> appserver...
> WEBLOGIC PLATFORM!
> deployed without getting any exceptions.
> or:
> greetings,
> chris from munich
Re: [BIRT2.2RC0 Deployment] BEA Weblogic 8.1.x [message #243212 is a reply to message #243190] Tue, 19 June 2007 02:06 Go to previous messageGo to next message
Hi Jason,
thx for the quick reply. I just tried rc2 ond rc3 and got the same
exception:
[Deployer:149033]preparing application birtRC3 on myserver
[Deployer:149033]failed application birtRC3 on myserver
[Deployer:149034]An exception occurred for task [Deployer:149026]Deploy
application birtRC3 on myserver.:
Exception:weblogic.management.ApplicationException: prepare failed for
birt2
Module: birt2 Error: Could not load birt2:
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
and after removing the
org.eclipse.equinox.registry_3.3.0.v20070522.jar
the error disappereared and the webviewerexample was succesfully deployed.
(birt still doesnŽt run on my weblogic, i guess there are some config
issues to solve...)
and well, there werenŽt that much "pain points" in using birt. i did hard
in getting familiar with this framework at the beginning (like it is with
any new stuff..), but after a time i found a lot of help googeling the net
and reading the newsgroup here.
there were some points on which i was stuck for a long time (mainly using
the RE):
- parameter disposal (parsing dateTime from any format to the only one
birt wants to see)
- exporting data (maybe some parameter like ...&__format=csv would be more
adequate)
- embedding reportViewer and parameterPage to a jsp-Site (the taglib is
great, but <iframe> ..?)
in summary i think birt is a great tool. using it you sure get across some
sharp edges, but after some practice you can handly it.
Re: [BIRT2.2RC0 Deployment] BEA Weblogic 8.1.x [message #243222 is a reply to message #243212] Tue, 19 June 2007 02:22 Go to previous messageGo to next message
bugzilla entry.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=193262
Re: [BIRT2.2RC0 Deployment] BEA Weblogic 8.1.x [message #243284 is a reply to message #243222] Tue, 19 June 2007 08:04 Go to previous messageGo to next message
i forgot to mention the exception of the viewerServlet:
org.eclipse.birt.report.exception.ViewerException: Fatal error occurred
when try to startup report engine.
org.eclipse.birt.report.service.ReportEngineService.setEngin eContext(Unknown
Source)
org.eclipse.birt.report.service.BirtViewerReportService.setC ontext(Unknown
Source)
at org.eclipse.birt.report.servlet.ViewerServlet.__getContext(U nknown
Source)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
weblogic.servlet.internal.ServletStubImpl$ServletInvocationA ction.run(ServletStubImpl.java:971)
weblogic.servlet.internal.ServletStubImpl.invokeServlet(Serv letStubImpl.java:402)
weblogic.servlet.internal.ServletStubImpl.invokeServlet(Serv letStubImpl.java:305)
weblogic.servlet.internal.WebAppServletContext$ServletInvoca tionAction.run(WebAppServletContext.java:6350)
weblogic.security.acl.internal.AuthenticatedSubject.doAs(Aut henticatedSubject.java:317)
weblogic.security.service.SecurityManager.runAs(SecurityMana ger.java:118)
weblogic.servlet.internal.WebAppServletContext.invokeServlet (WebAppServletContext.java:3635)
weblogic.servlet.internal.ServletRequestImpl.execute(Servlet RequestImpl.java:2585)
at weblogic.kernel.ExecuteThread.execute(ExecuteThread.java:197 )
at weblogic.kernel.ExecuteThread.run(ExecuteThread.java:170)
maybe it could be related to this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=136818
Re: [BIRT2.2RC0 Deployment] BEA Weblogic 8.1.x [message #243346 is a reply to message #243284] Tue, 19 June 2007 11:57 Go to previous message
Chris,
Thanks for the responses. We will look into the bug.
Jason
> at
> Source)
> at
> Source)
> at
> org.eclipse.birt.report.servlet.ViewerServlet.__getContext(U nknown Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:".pdf" extension is missing when exporting report to PDF
Next Topic:Accessing ODBC data
Current Time: Sun Aug 31 08:04:21 EDT 2025
Powered by FUDForum. Page generated in 0.04628 seconds
