Group On / Expression Builder [message #243077] |
Mon, 18 June 2007 03:53  |
Originally posted by: damian.delcampo.sealink.com.au
Hello all, can somebody please help me with hopefully a simple syntax
question ?
I'm trying to allow users to specify via a pararmeter the grouping on a
report.
If I specify the following in Expression Builder for a column called
Client_Code, the report is grouped by that column accordingly.
row["Client_Code"]
If I try to insert a conditional statement the report returns with no
data. I've reduced the Expression Builder statement down to the
following which I'd believe should give me the same as above.
if (true)
row["Client_Code"]
else if (false)
row["System_User_Code"]
Can somebody please tell me where I'm going wrong ??
Additionally, does anybody know of a reference manual online for
Expression Builder, the BIRT help is fairly skimpy in this area ??
Thanks in advance,
Damian Del Campo
Re: Group On / Expression Builder [message #243608 is a reply to message #243430] |
Wed, 20 June 2007 11:39  |
Hello Damian,
I have used conditional grouping using DE API, so I didnt need to use
expression, but I think its possible, the report will not return any data
only when there's an error , if you could run the report using the run
servlet i.e in the HTML view mode in the IDE you would be able to see the
errors/exceptions if any.
Did you try viewing the report in the HTML mode in the IDE?
FUDForum. Page generated in 0.26792 seconds
