Problem migrating 2.1 plugin to Eclispe 3.0M8 [message #243070] |
Fri, 21 May 2004 00:54 |
We have a plugin that works fine on 2.1. I tried the plugin on 3.0 and i
keep getting following error.
Any ideas ?
!ENTRY org.eclipse.core.runtime 4 2 May 21, 2004 00:44:27.127
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/jface/wizard/Wizard
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java(Compiled Code))
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.define
Class(DefaultClassLoader.java(Inlined Compiled Code))
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClass
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findCl
assImpl(DefaultClassLoader.java(Compiled Code))
ass(DefaultClassLoader.java(Compiled Code))
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(A
bstractClassLoader.java(Inlined Compiled Code))
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseCl
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleL
org.eclipse.osgi.framework.internal.core.BundleLoader.requir eClass(BundleLoa
org.eclipse.osgi.framework.internal.core.BundleLoader.findRe quiredClass(Bund
leLoader.java(Compiled Code))
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader
..java(Compiled Code))
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(Abstra
ctClassLoader.java(Compiled Code))
at java.lang.ClassLoader.loadClass(ClassLoader.java(Compiled Code))
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader
..java:251)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.jav
a:332)
org.eclipse.osgi.framework.internal.core.Bundle.loadClass(Bu ndle.java:1294)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExte
nsion(ConfigurationElement.java:132)
nsion(ConfigurationElement.java:125)
nsion(ConfigurationElement.java:114)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:189)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java
:186)
org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eExecutableExten
sion(WorkbenchWizardElement.java:96)
org.eclipse.ui.internal.dialogs.ImportWizard$1.createWizard( ImportWizard.jav
a:50)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$2.run(Wo rkbenchWizardNod
e.java:133)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:610)
at org.eclipse.core.runtime.Platform.run(Platform.java:521)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$1.run(Wo rkbenchWizardNod
e.java:114)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode.getWizar d(WorkbenchWizar
dNode.java:112)
org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(Wiz ardSelectionPage
..java:96)
org.eclipse.ui.internal.dialogs.WorkbenchWizardSelectionPage .getNextPage(Wor
kbenchWizardSelectionPage.java:82)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:675)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:314)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:413)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled
Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:769)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2578)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2256)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:670 )
at org.eclipse.jface.window.Window.open(Window.java:650)
org.eclipse.ui.actions.ImportResourcesAction.run(ImportResou rcesAction.java:
146)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:550)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionI
tem.java:502)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContribu
tionItem.java:435)
Code))
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1562)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1536)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:257)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:90)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:277)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:239)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:117)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:84
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:59)
at java.lang.reflect.Method.invoke(Method.java:390)
at org.eclipse.core.launcher.Main.basicRun(Main.java:267)
at org.eclipse.core.launcher.Main.run(Main.java:692)
at org.eclipse.core.launcher.Main.main(Main.java:676)
!ENTRY org.eclipse.ui 4 4 May 21, 2004 00:44:27.137
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 May 21, 2004 00:44:27.147
!MESSAGE
!STACK 0
java.lang.IllegalArgumentException:
at org.eclipse.core.internal.runtime.Assert.isLegal(Assert.java :56)
at org.eclipse.core.internal.runtime.Assert.isLegal(Assert.java :41)
at org.eclipse.core.runtime.Status.setPlugin(Status.java:165)
at org.eclipse.core.runtime.Status.<init>(Status.java:73)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$2.handle Exception(Workbe
nchWizardNode.java:121)
org.eclipse.core.internal.runtime.InternalPlatform.handleExc eption(InternalP
latform.java:345)
:614)
e.java:114)
dNode.java:112)
..java:96)
Code))
146)
tem.java:502)
tionItem.java:435)
Code))
java:277)
..java:59)
FUDForum. Page generated in 0.04882 seconds
