| GEF commandStack [message #243061] |
Wed, 21 May 2008 10:22 |
Originally posted by: yifanzhou.gmx.de
Hi, everyone,
I wrote the connectionCommand for connecting two models. It works well but
the command didn't be added into the command stack, so that means if I click
the undo button after creating a connection between two models. The last
created model was deleted. I've debugged it, I found the connection command
wasn't in the command stack. I don't know what the problem is? I think it
should work after the execute method in the connection command was invoked.
But it seemed it's not there. If anyone has encounted such problem before.
Thank you in advanced
yifan
FUDForum. Page generated in 0.03278 seconds
