Home » Eclipse Projects » JFace » CheckboxTreeViewer - correct CellEditor and Checkbox only at root elements?
CheckboxTreeViewer - correct CellEditor and Checkbox only at root elements? [message #23875] Fri, 24 July 2009 06:50 Go to next message
Hi everyone,
I am confused about the API of a CheckboxTreeViewer (Galileo Release).
The Javadoc for setCellEditors says:
"Since 3.3, an alternative API is available, see ViewerColumn.setEditingSupport(EditingSupport) for a more flexible way of editing values in a column viewer."
But the class TreeColumn doesn't seem to have the API mentioned.
Also the snippet in [1] refers to a TableViewer, not to a TreeViewer.
So what is the correct way of using cell editors here?
Still using setCellEditors, setColumnProperties, and setCellModifier?
And I am wondering if it is possible to have checkboxes only for root elements?
Right now, all elements in the tree have a checkbox attached.
Best regards
Patrick
[1] http://wiki.eclipse.org/JFaceSnippets#Snippet034CellEditorPe rRowNewAPI
Re: CheckboxTreeViewer - correct CellEditor and Checkbox only at root elements? [message #23994 is a reply to message #23875] Fri, 24 July 2009 10:44 Go to previous messageGo to next message
Hi again,
A follow-up question about checkboxes - I am not sure how to handle them:
If I use a cell editor to modify some data and call viewer.refresh(), all the checkbox states are gone, i.e. all items are unchecked again.
The workaround I see here is to manually iterate over all items again and set the checkbox state for each item.
Furthermore, after a refresh the entire tree is collapsed again.
Is there a trick how I can easily restore the state (collapsed/expanded items and the checkbox state) after a refresh?
Best regards
Patrick
On 24-07-2009 12:50, Patrick Könemann wrote:
> Hi everyone,
> elements?
> Best regards
> Patrick
Re: CheckboxTreeViewer - correct CellEditor and Checkbox only at root elements? [message #24329 is a reply to message #23875] Mon, 27 July 2009 12:55 Go to previous messageGo to next message
"Patrick Könemann" <pk@imm.dtu.dk> wrote in message
news:h4c3lk$m31$1@build.eclipse.org...
Look at TreeViewerColumn.
I'd use setEditingSupport.
> elements?
I don't know the answer to this. I assume it is all or nothing with
checkboxes on a tree.
-Will
Re: CheckboxTreeViewer - correct CellEditor and Checkbox only at root elements? [message #372840 is a reply to message #24329] Wed, 29 July 2009 07:08 Go to previous messageGo to next message
Thanks Will, I'll give the TreeViewerColumn a try as soon as I have time.
Concerning the checkboxes, I use the workaround to mark the checkboxes gray of all elements which should not be checkable (using setGrayedElements).
Not the nicest solution, but it at least it works.
Best regards
Patrick
>> elements?
> -Will
Re: CheckboxTreeViewer - correct CellEditor and Checkbox only at root elements? [message #372841 is a reply to message #23994] Wed, 29 July 2009 07:11 Go to previous message
Strange... I don't know what happened, but I cannot reproduce that behavior.
Now a refresh doesn't destroy the state of the tree any more :-D
Patrick
On 24-07-2009 16:44, Patrick Könemann wrote:
> Hi again,
> Best regards
> Patrick
Previous Topic:Problems with org.eclipse.jface.text source
Next Topic:TextViewer and revealRange
Current Time: Sat Jul 26 12:41:38 EDT 2025
Powered by FUDForum. Page generated in 0.04621 seconds
