Home » Archived » BIRT » Europa Test
Europa Test [message #243051] Mon, 18 June 2007 00:44 Go to next message
Originally posted by: irbull.cs.uvic.ca
Because of some previous errors I was receiving while testing for
Europa, I decided to D/L Eclipse 3.3 RC4, and update to the latest
version of all Europa projects.
When trying to create a report I get the following error:
java.lang.NoClassDefFoundError:
org/apache/batik/transcoder/TranscoderException
org.eclipse.birt.report.designer.internal.ui.wizards.WizardT emplateChoicePage$1.handleEvent(WizardTemplateChoicePage.jav a:462)
org.eclipse.birt.report.designer.internal.ui.wizards.WizardT emplateChoicePage.createControl(WizardTemplateChoicePage.jav a:359)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.ja va:170)
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:669)
org.eclipse.jface.wizard.WizardDialog.createContents(WizardD ialog.java:543)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1081)
org.eclipse.ui.internal.actions.NewWizardShortcutAction.run( NewWizardShortcutAction.java:122)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Re: Europa Test [message #243056 is a reply to message #243051] Mon, 18 June 2007 01:07 Go to previous message
I have opened a bug for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=193058
cheers,
ian
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:RenderTask ignoring referenced CSS file for HTML output?
Next Topic:New Eclipse BIRT Milestone Build Available for Download
Current Time: Tue Nov 18 21:40:22 EST 2025
Powered by FUDForum. Page generated in 0.03932 seconds
