| org.eclipse.draw2d.AbstractHintLayout questions [message #243043] | Tue, 20 May 2008 17:46  |  |
| Eclipse User  |  |  |  |  | Originally posted by: juergen.scheffler.gmx.de
 Hi everybody,
 Im German and dont really understand this class. But I understand the
 subclasses of it.
 (BorderLayout, FlowLayout, ScrollPaneLayout, StackLayout, ToolbarLayout,
 ViewportLayout)
 1. Which function does AbstractHintLayout layout have and what does the
 sentense "The foundation for layout managers which are sensitive to
 width and/or height hints. This class will cache preferred and minimum
 sizes for a given set of hints." mean?
 2. Mabye you can help me, if you explain one of these methods:
 -Dimension calculateMinimumSize(IFigure container, int wHint, int hHint)
 Calculates the minimum size using the given width and height
 hints.
 -Dimension getMinimumSize(IFigure container, int w, int h)
 Returns the minimum size of the given figure.
 -Dimension getPreferredSize(IFigure container, int w, int h)
 Returns the preferred size of the given figure, using width
 and height hints.
 please help! ;)
 Greetings
 JS
FUDForum. Page generated in 0.46561 seconds
