Home » Eclipse Projects » Eclipse Platform » Eclipse not seeing all CVS projects
Eclipse not seeing all CVS projects [message #243040] Thu, 20 May 2004 18:21 Go to next message
Originally posted by: brad.securedevelopment.com
I have recently started using CVS from within Eclipse. I have 3 projects
in a repository which all appear fine from a CVS point of view outside of
Eclipse. Yet through Eclipse CVS Repository Perspective I can only see one
of the 3 projects. As far as I can recall I set up each project the same
way by using CVS import.
I have seen this https://bugs.eclipse.org/bugs/show_bug.cgi?id=45138.
Any suggestions or what additional info does one need to help me.
Re: Eclipse not seeing all CVS projects [message #243814 is a reply to message #243040] Sat, 22 May 2004 21:07 Go to previous messageGo to next message
More details:
I have a repository location defined.
(:pserver:kbsimm@localhost:/global_dir/cvsroot). Expanding the repostitory
shows HEAD, Branches, and Versions. Expanding HEAD shows only one of 3 cvs
managed projects.
If I right click on the repository (:pserver:kbsimm.....) and select
Refresh Branches... I get a wizard that asks me to "Select the remote
projects whose tags should be refreshed". And shows all 3 projects plus
the CVSROOT directory (as if it where a project also). This is the only
location where I see the other 2 projects. hmmmmmm???
thanks
Brad
Re: Eclipse not seeing all CVS projects [message #245082 is a reply to message #243814] Tue, 25 May 2004 13:46 Go to previous message
Brad,
Do you have a working set enabled on the Repositories view?
Michael
Brad Simmons wrote:
> More details:
> managed projects.
> thanks
> Brad
Previous Topic:Getting access to problem log
Next Topic:CVS read/write connections
Current Time: Mon Oct 27 23:50:22 EDT 2025
Powered by FUDForum. Page generated in 0.04053 seconds
