Home » Newcomers » Newcomers » Where is org.eclipse.jface.viewers.SimpleStyledCellLabelProvider
Where is org.eclipse.jface.viewers.SimpleStyledCellLabelProvider [message #243031] Thu, 13 December 2007 18:07 Go to next message
Originally posted by: lforejtn.seznam.cz
Hi, does anybody know, where to get the version of org.eclipse.jface.jar
with the class org.eclipse.jface.viewers.SimpleStyledCellLabelProvider.
This class is needed to run several examples from
org.eclipse.jface.snippets project (offered by CVS at
dev.eclipse.org/cvsroot/eclipse). Thanks. LF
Re: Where is org.eclipse.jface.viewers.SimpleStyledCellLabelProvider [message #243063 is a reply to message #243031] Fri, 14 December 2007 09:34 Go to previous messageGo to next message
You need to wait for M4 or checkout JFace from CVS-HEAD.
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Where is org.eclipse.jface.viewers.SimpleStyledCellLabelProvider [message #243074 is a reply to message #243063] Fri, 14 December 2007 09:35 Go to previous messageGo to next message
M4 is due for today ;-)
> Tom
>> org.eclipse.jface.jar with the class
>> org.eclipse.jface.viewers.SimpleStyledCellLabelProvider. This class is
>> needed to run several examples from org.eclipse.jface.snippets project
>> (offered by CVS at dev.eclipse.org/cvsroot/eclipse). Thanks. LF
Re: Where is org.eclipse.jface.viewers.SimpleStyledCellLabelProvider [message #243079 is a reply to message #243031] Fri, 14 December 2007 09:36 Go to previous messageGo to next message
It is probably new to Eclipse 3.4. If you pulled the snippets project
from CVS head then you also need the latest versions of SWT and JFace
projects from CVS head (and maybe more projects, too).
Hope this helps,
Eric
Re: Where is org.eclipse.jface.viewers.SimpleStyledCellLabelProvider [message #243235 is a reply to message #243031] Fri, 14 December 2007 18:35 Go to previous message
Eric and Tom, thanks for the tips. It helps to load the org.eclipse.jface
and org.eclipse.commands project into the same workspace.
Previous Topic:Eclipse 3.3.1.1 uses 50% of CPU at idle
Next Topic:Editor Window Tabs Display Problem
Current Time: Sun Aug 31 08:04:12 EDT 2025
Powered by FUDForum. Page generated in 0.08908 seconds
