Marquee in GEF [message #23866] |
Fri, 04 October 2002 18:55  |
Does/Will GEF support Cut-And-Paste components selected by Marquee in GEF?
Or each application should implement its 'cut-and-paste' instead?
I check the Logic editor example, it does not show it can "cut-and-paste"?
And how can I change the bounder of the marguee region?
Thank you.
Re: Marquee in GEF [message #24948 is a reply to message #24607] |
Mon, 07 October 2002 10:28   |
Thanks.
Is there a way to change the border of the Marquee region (change as you
move the mouse)? Right now, it is White and the background of the editor is
White, it is hard to see what components are in the Marquee region.
Thanks again.
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:anqkv9$u12$1@rogue.oti.com...
> "Hal" <otaconss2@hotmail.com> wrote in message
> news:anq1hg$nat$1@rogue.oti.com...
> > Thanks. Do you know is/will "Rotate" a feature of GEF also?
> We cannot support general rotate because there is no way to rotate fonts
or
> images. Look at PolygonDecoration. This class takes a PointList template,
> and applies a rotation, scale, and translation to generate a "result"
> Pointlist, which is then used to paint. While this class is used to
create
> arrowheads at the ends of connections, you can reuse the Transform class
to
> write your own polygon figure. Or open a feature request.
> > "Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
> > news:anlnf5$47u$1@rogue.oti.com...
> > > Cut and Paste is something currently on my agenda. If everything goes
> > well
> > > (does it ever?), I'll work on this next week. I'll post when it's
done
> > and in CVS.
> > > Eric
in
> > GEF?
> > "cut-and-paste"?
> > > > Thank you.
Re: Marquee in GEF [message #25078 is a reply to message #24948] |
Mon, 07 October 2002 12:17   |
news:ans4bd$lmn$1@rogue.oti.com...
> Thanks.
is
> Thanks again.
For me the marquee region is outlined with a dashed black and white line.
What are you asking for? Do you want it animated? We should probably
change it to use XOR painting as well.
> or
template,
> create
> to
goes
> > > well
> done
> > > and in CVS.
> > > > Eric
> in
> > > GEF?
> > > "cut-and-paste"?
> > > > > Thank you.
Re: Marquee in GEF [message #25161 is a reply to message #25078] |
Mon, 07 October 2002 18:51  |
I am running on Window NT with the latest GEF release. But I don't see a
dashed black line.
How can I set the border color of the marquee region?
news:ansaoe$qaj$1@rogue.oti.com...
> > Thanks.
> is
> > Thanks again.
fonts
> > or
> template,
> > create
class
> > to
> goes
> > > > well
> > done
> > > > and in CVS.
> > > > > Eric
Marquee
> > in
> > > > GEF?
instead?
> > > > "cut-and-paste"?
> > > > > > Thank you.
FUDForum. Page generated in 1.04094 seconds
