Home » Eclipse Projects » GEF » Marquee in GEF
Marquee in GEF [message #23866] Fri, 04 October 2002 18:55 Go to next message
Does/Will GEF support Cut-And-Paste components selected by Marquee in GEF?
Or each application should implement its 'cut-and-paste' instead?
I check the Logic editor example, it does not show it can "cut-and-paste"?
And how can I change the bounder of the marguee region?
Thank you.
Re: Marquee in GEF [message #23992 is a reply to message #23866] Sat, 05 October 2002 00:11 Go to previous messageGo to next message
Cut and Paste is something currently on my agenda. If everything goes well
(does it ever?), I'll work on this next week. I'll post when it's done and in CVS.
Eric
> Thank you.
Re: Marquee in GEF [message #24276 is a reply to message #23992] Sun, 06 October 2002 15:28 Go to previous messageGo to next message
Thanks. Do you know is/will "Rotate" a feature of GEF also?
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:anlnf5$47u$1@rogue.oti.com...
well
and in CVS.
> Eric
GEF?
"cut-and-paste"?
> > Thank you.
Re: Marquee in GEF [message #24607 is a reply to message #24276] Sun, 06 October 2002 20:59 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
"Hal" <otaconss2@hotmail.com> wrote in message
news:anq1hg$nat$1@rogue.oti.com...
We cannot support general rotate because there is no way to rotate fonts or
images. Look at PolygonDecoration. This class takes a PointList template,
and applies a rotation, scale, and translation to generate a "result"
Pointlist, which is then used to paint. While this class is used to create
arrowheads at the ends of connections, you can reuse the Transform class to
write your own polygon figure. Or open a feature request.
> well
> and in CVS.
> > Eric
> GEF?
> "cut-and-paste"?
> > > Thank you.
Re: Marquee in GEF [message #24948 is a reply to message #24607] Mon, 07 October 2002 10:28 Go to previous messageGo to next message
Thanks.
Is there a way to change the border of the Marquee region (change as you
move the mouse)? Right now, it is White and the background of the editor is
White, it is hard to see what components are in the Marquee region.
Thanks again.
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:anqkv9$u12$1@rogue.oti.com...
or
create
to
> > well
done
> > and in CVS.
> > > Eric
in
> > GEF?
> > "cut-and-paste"?
> > > > Thank you.
Re: Marquee in GEF [message #25078 is a reply to message #24948] Mon, 07 October 2002 12:17 Go to previous messageGo to next message
news:ans4bd$lmn$1@rogue.oti.com...
> Thanks.
is
> Thanks again.
For me the marquee region is outlined with a dashed black and white line.
What are you asking for? Do you want it animated? We should probably
change it to use XOR painting as well.
> or
template,
> create
> to
goes
> > > well
> done
> > > and in CVS.
> > > > Eric
> in
> > > GEF?
> > > "cut-and-paste"?
> > > > > Thank you.
Re: Marquee in GEF [message #25161 is a reply to message #25078] Mon, 07 October 2002 18:51 Go to previous message
I am running on Window NT with the latest GEF release. But I don't see a
dashed black line.
How can I set the border color of the marquee region?
news:ansaoe$qaj$1@rogue.oti.com...
> > Thanks.
> is
> > Thanks again.
fonts
> > or
> template,
> > create
class
> > to
> goes
> > > > well
> > done
> > > > and in CVS.
> > > > > Eric
Marquee
> > in
> > > > GEF?
instead?
> > > > "cut-and-paste"?
> > > > > > Thank you.
Previous Topic:Change the cursor in GEF
Next Topic:Hello Gef #1 : a first tutorial example (comments welcome)
Current Time: Tue Jul 22 08:26:19 EDT 2025
Powered by FUDForum. Page generated in 0.04485 seconds
