Home » Eclipse Projects » GEF » Regarding Connection Endpoint Locator
Regarding Connection Endpoint Locator [message #242904] Tue, 13 May 2008 08:01 Go to next message
Originally posted by: rajeev.singh.gm.com
I'm new to GEF and I was going through the sample Draw2D code provided in
CVS.
I was going through the code of ConnectionAndAnchorExample.java provided
for Connections and ConnectionEndpointLocator.
When we move the node, labels attached to the connection also moves.
My question is what can be done so that end points labels attached to
connection never intersect with connection?
Rajeev.
Re: Regarding Connection Endpoint Locator [message #242915 is a reply to message #242904] Tue, 13 May 2008 10:13 Go to previous message
I think you will have to write your own Locator to do that, probably taking
ConnectionEndPointLocator as an example.
"Rajeev" <rajeev.singh@gm.com> wrote in message
news:bcaba36ce9aae471437f247aeda6e582$1@www.eclipse.org...
> CVS.
> Rajeev.
Previous Topic:GEF environment with TinyDT
Next Topic:ComboBoxPropertyDescriptor proplem
Current Time: Sun Aug 31 21:06:08 EDT 2025
Powered by FUDForum. Page generated in 0.05345 seconds
