Running RCP on MacOS Leopard [message #242893] |
Wed, 12 December 2007 10:24  |
Originally posted by: "jakub,jurkiewicz".gmail.com
I have just switched from Windows to Mac and faced a problem with
running my RCP application from Eclipse (as Eclipse application). I've
got the same configuration as on Windows, where everything was just fine.
I've got Eclipse 3.3.1.1 and MacOS Leopard.
When I run my application I get the following error:
java.lang.UnsatisfiedLinkError: no swt-carbon-3347 or swt-carbon in
swt.library.path, java.library.path or the jar file
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:21 9)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:15 1)
at org.eclipse.swt.internal.C.<clinit>(C.java:21)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:9 45)
at org.eclipse.swt.widgets.Display.create(Display.java:939)
at org.eclipse.swt.graphics.Device.<init>(Device.java:119)
at org.eclipse.swt.widgets.Display.<init>(Display.java:749)
at org.eclipse.swt.widgets.Display.<init>(Display.java:740)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:498)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
org.eclipse.ui.internal.ide.application.IDEApplication.creat eDisplay(IDEApplication.java:133)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:86)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Any idea what I should do to make it run?
Thanks in advance for your help :)
kind regards,
Jakub Jurkiewicz
http://eclipser-blog.blogspot.com
Re: Running RCP on MacOS Leopard [message #245253 is a reply to message #243006] |
Fri, 11 January 2008 05:28  |
Originally posted by: svo.ciklum.net
I faced exactly the same problem. It really looks like
org.eclipse.swt.carbon.macosx plugin is not in the list of dependencies
of our project, and, of course, it is not present in the runtime
classpath. But I couldn't add it manually neither. Can you help?
Thanks in advance,
Stanislav
Eric Rizzo wrote:
> Jakub Jurkiewicz wrote:
> Check the launch configuration you're using to run the app; make sure
> that the swt-carbon plugin(s) is included in the list of plugins.
> Hope this helps,
> Eric
FUDForum. Page generated in 0.11692 seconds
