Accessing ODBC data [message #242890] |
Fri, 15 June 2007 03:48  |
Originally posted by: luc.dooms.c-cure.be
Hi All,
I have been working with BIRT to report on some of MySQL data and I'm
pretty impressed with the results so far.
Now, I need to include some MS Access data, data I can only access through
ODBC.
Does anybody has a proven method to do this ?
1. I know that sun has a JDBC/ODBC bridge included the JDK.
Is that the way to go?
How do you include this bridge into the BIRT Managed Drivers?
2. I have also tried the hxtt MS Access JDBC drivers.
They do work for small MS Access tables, but fail with the larger ones.
Your documented experiences are welcome !
Luke
Re: Accessing ODBC data [message #243351 is a reply to message #243258] |
Tue, 19 June 2007 12:19  |
Luke,
You should be able to type in
sun.jdbc.JdbcOdbcDriver as the driver class. It is not in the drop
down, but you can type it in.
the jdbc:odbc:mydb is the url.
Jason
Luke wrote:
> Hi Jason,
> Thanks for your answer.
> Still, jdbc:odbc:mydb is simply not in the options of my 'Driver Class'
> list.
> So I need to include it by using the 'Manage Driver...'.
> But I don't know what JAR file to add.
> Anybody ?
> Luc
> Jason Weathersby wrote:
>> Luke,
>> You can access a ODBC source by entering
>> sun.jdbc.odbc.JdbcOdbcDriver as the driver class.
>> The driver url would be something like:
>> jdbc:odbc:mydb
>> Jason
>> Luke wrote:
>>> Hi All,
>>> through ODBC.
>>> Cheers,
>>> Luke
FUDForum. Page generated in 0.04435 seconds
