Problems with Border, setClip() and getInsets() [message #242872] |
Mon, 12 May 2008 07:44  |
--------------050503080708030903010102
I'm having trouble defining my own border. I'm trying to do something
like a UML "multi-object" (see attached pic). This works so far, but
only if I use the setClip method as shown in the attached class (I've
learned that from some example code). But this seems to be causing
trouble with repainting in some situations...
In fact, I've seen a message where somebody suggests not to use
setClip() - returning appropriate Insets shall be the solution.
Unfortunately, I can't find the message in this newsgroup any more.
So I tried to return Insets as can be seen in the code, but my border
wouldn't appear, so I switched back to the setClip() solution for now.
Can anybody help me figuring out what I'm doing wrong?
Thanks in advance,
Chris
Content-Type: image/gif;
name="MultiObject.gif"
Content-Disposition: inline;
filename="MultiObject.gif"
R0lGODlhigBdAPcAAAQCBPz+/ERCRAAAAAUcnCPqDwATYgAAACG+qCKUbAA2 hgB+AAANIgCO
eBY3NwB+fg/gYAAPDwAODgAAAAAgqAIAbAAAhgAAAACc4AMP6gBiEwAAACgB mOkA9RMANwAC
ftEAqOUAbIEAhnwAAACeoAACOAEAgQAAAFYBAAAAAAAAAAAAADDMQOj1ZBMT UAAAAEcgAQAg
AABGAAAAAFAgEukAJBMAAQAAGAA07OmH7pE2E3x+AECy4wAOuJILRXwAAP8E YP8QD/8ADv8A
AD0x6AAzuJI4RXwgAG14AOcgAIE5AHwzAAAgGgB4AxYgAAAyAFg0CQMgkABC NwBQfhhQ+RYA
lhcASAAAAJAcnGvqDxYTYgAAAAAohADC6wA3EwB+AH7gKAAP7wAOE8AAAAAg kAAAkwAASAAA
AP+c7P8P7v9iE/8AAP8BAP8AAP8AAP8CAAAB/wAA/wAA/wAA/wDZ/QCLmQA2 gAB+fACIaQAQ
7BY8OgB+d7ewQN3pLAATFwAAAGBkAOnq7BMTEwAAAIc8AOvCAIE3AHx+ADPp B+PBAIE3AHx+
AKDMAHf1AFATAAAAAJAgAGsgAAFGFgAAAGsgAAAAAAAAAAAAAJy3AOjdABMA AAAAADR4AADq
AAATAMAAAAidAPwrABODAAB8AAAASOkAAJEArnwAAEAAAAAAAJIAAHwAAP8A AP8AAP8AAP8A
AD0APAABAJIAAHwAANoBPPQsAICDAHx8AACcWADq8RYTEwAAAADc/wAr/wCD /wB8/5AAAGsA
ABYAAAAAAABMpAEA6wCuEwAAAABM9gBkOACDTAB8AOf/hPT/64D/E3z/AIig d+rrEBMTTwAA
AJCFuGtk6xaDEwB8AEBoTGQsZFBPgwAAfAGAbAA17ABPEwAAAEAAwmQB/1AA /wAAf+GcML3q
7EUTEwAAANMATAsBAP8Arv8AAGCgTA9kZA6DgwB8fAwBTAAAAAAArgAAAAAA twAA3QAwAAAA
AEBcAGQAAFBQAAAAAFi8jeps4hOGRwAAACH5BAAAAAAALAAAAACKAF0ABwj/ AAMIHEiwoMGD
CBMqXMiwocOHECNKnEixosWLGDNq3Mixo8ePIEOKHEmypMmTKFOqXMmypcuX MGPKnEmzps2b
OHPq3Mmzp8+fQIMKHUq0qNGjSJMqXcq0qdOnUKNaBEC1qtWrWLNq3cq1K9ee XsOKHUtWK0+q
StHuVIuUbU63RuHelEuUbsyyePPqdWsX5t6/gL8O7PuSsE++AHAaBpt4cGOb i88+DhB5ZWWd
iBVPrjv5ckrPmgmCPjkacufNM0vXzDwXtVDWptueDn0U9mrXQW3TVL17duuO uEXqTh2csu+E
xUEOl0l4uWiVzv26bpyYOmWBVbFff0w9+/aN0QtPwddufXN169fTk08eMbzL 5umrF5RPfvBz
9u2P31bYXbtxtNydZpV6GrnXEnzG1afgd/49x5GBLNGF3n32cedfZwRmBKFl 42UYX3YWXugd
fhBtCB2JmOnXm0ECBDZWgSoSJ5toKH5WI23Y3UiajrE5hmNRJto4o4+/1RYj czzuR2SPcWX1
I2dXvZXkiowNKZmLWAJ2WJZc6iXVl2CGKeaYZJZp5plopqnmmmy26eabcMYp 55x01mnnnXjm
qeeefPZpZkAAOw==
Content-Type: text/x-java;
name="MultiObjectBorder.java"
filename="MultiObjectBorder.java"
cGFja2FnZSBkZS51cGIuZG1tLmVkaXRvci5kaWFncmFtLmN1c3RvbS5lZGl0 LnBhcnRzOwoK
aW1wb3J0IG9yZy5lY2xpcHNlLmRyYXcyZC5BYnN0cmFjdEJvcmRlcjsKaW1w b3J0IG9yZy5l
Y2xpcHNlLmRyYXcyZC5HcmFwaGljczsKaW1wb3J0IG9yZy5lY2xpcHNlLmRy YXcyZC5JRmln
dXJlOwppbXBvcnQgb3JnLmVjbGlwc2UuZHJhdzJkLlJlY3RhbmdsZUZpZ3Vy ZTsKaW1wb3J0
IG9yZy5lY2xpcHNlLmRyYXcyZC5nZW9tZXRyeS5JbnNldHM7CmltcG9ydCBv cmcuZWNsaXBz
ZS5kcmF3MmQuZ2VvbWV0cnkuUG9pbnQ7CmltcG9ydCBvcmcuZWNsaXBzZS5k cmF3MmQuZ2Vv
bWV0cnkuUmVjdGFuZ2xlOwoKcHVibGljIGNsYXNzIE11bHRpT2JqZWN0Qm9y ZGVyIGV4dGVu
ZHMgQWJzdHJhY3RCb3JkZXIgewoKCS8qKgoJICogdGhlICJzaXplIiBvZiB0 aGUgQm9yZGVy
CgkgKi8KCXByaXZhdGUgaW50IG9mZnNldDsKCglwdWJsaWMgTXVsdGlPYmpl Y3RCb3JkZXIo
aW50IG9mZnNldCkgewoJCXRoaXMub2Zmc2V0ID0gb2Zmc2V0OwoJfQoKCXB1 YmxpYyB2b2lk
IHBhaW50KElGaWd1cmUgYUZpZ3VyZSwgR3JhcGhpY3MgZ3JhcGhpY3MsIElu c2V0cyBpbnNl
dHMpIHsKCQl0ZW1wUmVjdC5zZXRCb3VuZHMoZ2V0UGFpbnRSZWN0YW5nbGUo YUZpZ3VyZSwg
aW5zZXRzKSk7CgoJCS8vIEZJWE1FIGJldHRlciB3YXkgdG8gZG8gdGhpcz8g V2hhdCBhYm91
dCBpbnNldHM/CgkJLy8gZXhwYW5kIHRoZSBjbGlwIHJlY3RhbmdsZS4uLgoJ CVJlY3Rhbmds
ZSBuZXdSZWN0ID0gbmV3IFJlY3RhbmdsZSh0ZW1wUmVjdCk7CgkJbmV3UmVj dC53aWR0aCA9
IG5ld1JlY3Qud2lkdGggKyBvZmZzZXQgKyAxOwoJCW5ld1JlY3QuaGVpZ2h0 ID0gbmV3UmVj
dC5oZWlnaHQgKyBvZmZzZXQgKyAxOwoJCW5ld1JlY3QueSA9IG5ld1JlY3Qu eSAtIChvZmZz
ZXQgKyAxKTsKCQlncmFwaGljcy5zZXRDbGlwKG5ld1JlY3QpOwoKCQkvLyBw YWludCBkZWNv
cmF0aW9uCgkJaW50IHhsID0gdGVtcFJlY3QueCArIG9mZnNldDsKCQlpbnQg eHIgPSB4bCAr
IHRlbXBSZWN0LndpZHRoOwoJCWludCB5dSA9IHRlbXBSZWN0LnkgLSBvZmZz ZXQ7CgkJaW50
IHlsID0geXUgKyB0ZW1wUmVjdC5oZWlnaHQ7CgkJUG9pbnQgbGVmdExvd2Vy ID0gbmV3IFBv
aW50KHhsLCB0ZW1wUmVjdC55ICsgMSk7CgkJUG9pbnQgbGVmdFVwcGVyID0g bmV3IFBvaW50
KHhsLCB5dSk7CgkJUG9pbnQgcmlnaHRVcHBlciA9IG5ldyBQb2ludCh4ciwg eXUpOwoJCVBv
aW50IHJpZ2h0TG93ZXIgPSBuZXcgUG9pbnQoeHIsIHlsKTsKCQlQb2ludCBl bmQgPSBuZXcg
UG9pbnQodGVtcFJlY3QueCArIHRlbXBSZWN0LndpZHRoIC0gMSwgeWwpOwoK CQlpZiAoYUZp
Z3VyZSBpbnN0YW5jZW9mIFJlY3RhbmdsZUZpZ3VyZSkgewoJCQlSZWN0YW5n bGVGaWd1cmUg
cmVjdGFuZ2xlRmlndXJlID0gKFJlY3RhbmdsZUZpZ3VyZSkgYUZpZ3VyZTsK CQkJaWYgKHJl
Y3RhbmdsZUZpZ3VyZS5nZXRGb3JlZ3JvdW5kQ29sb3IoKSAhPSBudWxsKSB7 CgkJCQlncmFw
aGljcy5zZXRGb3JlZ3JvdW5kQ29sb3IocmVjdGFuZ2xlRmlndXJlLmdldEZv cmVncm91bmRD
b2xvcigpKTsKCQkJfQoJCQlncmFwaGljcy5zZXRMaW5lV2lkdGgocmVjdGFu Z2xlRmlndXJl
LmdldExpbmVXaWR0aCgpKTsKCQl9CgkJZ3JhcGhpY3MuZHJhd0xpbmUobGVm dExvd2VyLCBs
ZWZ0VXBwZXIpOwoJCWdyYXBoaWNzLmRyYXdMaW5lKGxlZnRVcHBlciwgcmln aHRVcHBlcik7
CgkJZ3JhcGhpY3MuZHJhd0xpbmUocmlnaHRVcHBlciwgcmlnaHRMb3dlcik7 CgkJZ3JhcGhp
Y3MuZHJhd0xpbmUocmlnaHRMb3dlciwgZW5kKTsKCX0KCglAT3ZlcnJpZGUK CXB1YmxpYyBi
b29sZWFuIGlzT3BhcXVlKCkgewoJCXJldHVybiB0cnVlOwoJfQoKCXB1Ymxp YyBJbnNldHMg
Z2V0SW5zZXRzKEBTdXBwcmVzc1dhcm5pbmdzKCJ1bnVzZWQiKSBJRmlndXJl IGFGaWd1cmUp
IHsKCQlyZXR1cm4gbmV3IEluc2V0cygwKTsKLy8JCXJldHVybiBuZXcgSW5z ZXRzKG9mZnNl
dCwgMCwgMCwgb2Zmc2V0KTsKCX0KfQ==
--------------050503080708030903010102--
Re: Problems with Border, setClip() and getInsets() [message #242926 is a reply to message #242872] |
Wed, 14 May 2008 12:42   |
I had a similar problem, and I ended up just writing my own Figure for it. That
is a lot easier than trying to create a border. I can probably send you the code
for it, if you like.
Del
chris wrote:
> Thanks in advance,
> Chris
Re: Problems with Border, setClip() and getInsets() [message #242936 is a reply to message #242926] |
Thu, 15 May 2008 01:07  |
Hi Del,
that would be awesome. The only problem is that I need to add/remove
that border depending on a boolean attribute of the semantic element -
with your solution, I would have to learn how to exchange the figure of
an EditPart :-)
In fact, I thought it's pretty easy to write a custom border, but this
doesn't seem to be the case - does anybody have a solution to the
original problem?
Chris
> it. That is a lot easier than trying to create a border. I can probably
> send you the code for it, if you like.
> Del
> chris wrote:
>> Thanks in advance,
>> Chris
Olin Miller: "You probably wouldn't worry about what people think of you
if you could know how seldom they do."
FUDForum. Page generated in 0.03672 seconds
