org.osgi.framework.BundleException: in an GEF example [message #242862] |
Sun, 11 May 2008 10:15 |
Originally posted by: npchala.yahoo.com
I have a sample GEF code which was done by using GEF 2.1 and it is working
fine on Eclipse 2.1. (The first Shape Editor example in
http://eclipsewiki.editme.com/GefExamples), but i need to run it on
Eclipse 3.2 by using GEF 3.1 version. But it gives three errors as,
1. org.osgi.framework.BundleException: The activator
org.eclipse.ui.internal.ide.IDEWorkbenchPlugin for bundle
org.eclipse.ui.ide is invalid
2. org.osgi.framework.BundleException: The activator
org.eclipse.ui.internal.WorkbenchPlugin for bundle
org.eclipse.ui.workbench is invalid
3. org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.ui.ide was
unable to load class org.eclipse.ui.internal.ide.IDEApplication
I cant figure out these errors and i'm nt an expert in this area. Is it
due to an incompatibility issue? If so how can i get rid of those errors?
Thank you,
C.Lah
FUDForum. Page generated in 0.02351 seconds
