Home » Eclipse Projects » Eclipse Platform » Finding Java Problems based on their ID
Finding Java Problems based on their ID [message #242829] Thu, 20 May 2004 12:21 Go to next message
I posted this in eclipse.tools.jdt as well. Does anyone here have any idea
how this can be done?
Does anyone know of any way to get information about a Java problem
(IProblem) without having to get them from a specific compilation unit or a
marker? For example, i have problem id 32434245 and I want to find out what
the message for that id is. Can I do that?
Del.
Re: Finding Java Problems based on their ID [message #242853 is a reply to message #242829] Thu, 20 May 2004 13:15 Go to previous message
Originally posted by: olivier_thomannNO.ca.ibm.comSPAM
Le Thu, 20 May 2004 09:21:17 -0700, "Del" <delmyers@cs.uvic.ca> a
écrit :
I don't think there are API for this.
You can always look at the code in the compiler.
Look at the method getLocalizedMessage in
org.eclipse.jdt.internal.compiler.problem.DefaultProblemFact ory in the
jar file of the org.eclipse.jdt.core plugin.
Olivier
Previous Topic:Switching between languages in Info Center--seeing different behavior on different clients
Next Topic:Using IFile on a file outside of project folders
Current Time: Thu Nov 27 17:29:30 EST 2025
Powered by FUDForum. Page generated in 0.04040 seconds
