Home » Newcomers » Newcomers » restircting the output of CTRL+SHIFT+R
restircting the output of CTRL+SHIFT+R [message #242820] Tue, 11 December 2007 10:45 Go to next message
Originally posted by: harry.duin.gmail.com
I use the CTRL+SHIFT+R combi very often to load a Java class in the
editor. When I start typing the name of the class in the window, Eclipse
shows both .java and .class files for me to select from.
Is there a way to restrict the selection to .java files only?
Thanks, -hd
Re: restircting the output of CTRL+SHIFT+R [message #242830 is a reply to message #242820] Tue, 11 December 2007 14:00 Go to previous message
Originally posted by: zx.us.ibm.com
How about using Ctrl+Shift+T, which should only show you Classes :)?
~ Chris
Previous Topic:Problem with Help in Eclipse Europe (V3.3.1.1)
Next Topic:Listing classes loaded by application.
Current Time: Sun Aug 31 08:04:35 EDT 2025
Powered by FUDForum. Page generated in 0.07672 seconds
