Home » Eclipse Projects » GEF » Problems with IStorageEditorInput
Problems with IStorageEditorInput [message #242774] Thu, 08 May 2008 12:24 Go to next message
Originally posted by: 14.08.99.gmx.de
My little GEF-editor is embedded in an RCP. I want to save my Diagrams
in a database. So I decided to implement the interface
IStorageEditorInput in MyEditorInput (bad idea???).
The editor is called via an action in a package of the RCP.
MyEditorInput editorInput = new MyEditorInput();
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().openEditor((IEditorInput)
editorInput,MyEditor.ID);
Now I get an error. Eclipse wants me to configure the build path, but I
don't know in wich way... "The type org.eclipse.ui.IStorageEditorInput
cannot be resolved. It is indirectly referenced from
required .class files"
I tried some other interfaces. With IPathEditorInput (not useable for
storage in db) i got no probs...
Any ideas?
br,
Guido
Re: Problems with IStorageEditorInput [message #242785 is a reply to message #242774] Thu, 08 May 2008 13:20 Go to previous messageGo to next message
Guido,
In the plugin that's complaining, you need to add a dependency on the
org.eclipse.ui.ide plugin in the MANIFEST.MF's dependencies tab, but
that's the Eclipse IDE plugin, so not sure if you want to do that...
Guido Schwab wrote:
> I don't know in wich way... "The type
> org.eclipse.ui.IStorageEditorInput cannot be resolved. It is
> Any ideas?
> br,
> Guido
Re: Problems with IStorageEditorInput [message #242814 is a reply to message #242785] Fri, 09 May 2008 02:36 Go to previous messageGo to next message
You're right, I don't want to do that. Is there no other possiblity? Do
I have to write my own implementation of IEditorInput?
br,
Guido
Re: Problems with IStorageEditorInput [message #242827 is a reply to message #242814] Fri, 09 May 2008 06:51 Go to previous messageGo to next message
Guido,
Yes, I suspect that writing your own implementation is best. If you're
using EFS, I suppose maybe something based directly of IFileStore might
make sense. Or you might use IURIEditorInput and your application would
now how to interpret the URI with respect to the database.
> Do I have to write my own implementation of IEditorInput?
> br,
> Guido
dNdYkkZzJYL [message #244170 is a reply to message #242827] Tue, 08 July 2008 07:15 Go to previous message
Originally posted by: ewxwyk.sjvzvw.com
rt6ZII <a href="http://nlcsldgpkkhm.com/">nlcsldgpkkhm</a>,
kkmcyqzafriz,
fngvtjhppfhp[/link],
http://smmkqcrtcgac.com/
Previous Topic:Draggable text on connections
Next Topic:Getting Started
Current Time: Tue Jul 22 13:04:02 EDT 2025
Powered by FUDForum. Page generated in 0.04865 seconds
