Home » Eclipse Projects » GEF » Image map
Image map [message #242710] Mon, 05 May 2008 17:25 Go to next message
Originally posted by: Jefferey.xxx.xxx
I am newbie to GEF. I need to create an image map on the images.
Is GEF is the right approach to go or do I have to use any other eclipse
technology ? If somehow, I can do using SWT/Jface, that would work too.
Any help is appreciated. Thanks in advance.
Jeff.
Re: Image map [message #242760 is a reply to message #242710] Wed, 07 May 2008 13:47 Go to previous messageGo to next message
Can you explain what an image map is?
"Jeff" <Jefferey@xxx.xxx> wrote in message
news:e62f18467c0efd3eb10c8fe0aabc86ac$1@www.eclipse.org...
> Jeff.
Re: Image map [message #242809 is a reply to message #242760] Thu, 08 May 2008 19:56 Go to previous messageGo to next message
It's HTML <map> tag which I would like to insert on the image. Look here
for more information http://www.w3schools.com/TAGS/tag_map.asp
Thanks in advance
Re: Image map [message #242837 is a reply to message #242809] Fri, 09 May 2008 10:24 Go to previous message
The GEF is for graphical editing, so it sounds like a bit of an overkill for
your problem. I would think there are simpler ways to detect a mouse click
in a certain area.
news:654487d531609c43acdeee2ba3d90a8a$1@www.eclipse.org...
> Thanks in advance
Previous Topic:Re: Zoom in time too long
Next Topic:finding a figure off-screen
Current Time: Thu Nov 06 01:09:40 EST 2025
Powered by FUDForum. Page generated in 0.04082 seconds
