Home » Archived » BIRT » Problem in using the Web viewer with a PDF output
Problem in using the Web viewer with a PDF output [message #242683] Thu, 14 June 2007 08:00 Go to next message
Originally posted by: berenger.dulac.mnhn.fr
Hello, I try to use the BIRT Web viewer (BIRT Runtime 2.1.2) with a pdf
output format. Using the following URL :
http://192.134.151.114/TableauDeBord/run?__report=visites.rp tdesign&periode=01042007&__format=pdf
I get nothing in console and logs.
With Firefox 2, I am prompted with the message
"Le fichier ne commence pas par '%PDF-'"
What means "The file does not start with '%PDF-'"
With Internet Explorer 7, I got the following message on my web page :
"org.eclipse.birt.report.service.api.ReportServiceException: Report engine
fails to create extension to handle this request."
I have no problem when I replace the __format value "pdf" by "html".
It seems I do not call the URL with the right parameters (do I need an
outpout filename ?).
The report I call is "visites.rptdesign" and "periode" is a report
parameter.
Could anyone help me ?
Thanks.
Bérenger Dulac
Re: Problem in using the Web viewer with a PDF output [message #242725 is a reply to message #242683] Thu, 14 June 2007 10:51 Go to previous messageGo to next message
> engine fails to create extension to handle this request."
> parameter.
> Thanks.
> Bérenger Dulac
est-ce que t'a bien le itext dans ton installation.
j'ai eu le même problème, malheureusement j pas pu le résoudre sous
windows, alors que sou linux ça marchait bien.
Re: Problem in using the Web viewer with a PDF output [message #242947 is a reply to message #242683] Fri, 15 June 2007 07:42 Go to previous message
It might be useful to indicate I succeed in building the pdf document
directly from my application using the BIRT framework (separating run
and render).
Thanks for any help.
> parameter.
> Thanks.
> Bérenger Dulac
Previous Topic:Upgrade from 2.1.2 -> 2.2 :"Error in XML Source Page must be corrected before other pages ca
Next Topic:Incorrect Data Set from XML Data Source in BIRT 2.2M6?
Current Time: Sat Nov 08 12:03:23 EST 2025
Powered by FUDForum. Page generated in 0.02921 seconds
