Home » Archived » BIRT » PDF emitter
PDF emitter [message #242676] Thu, 14 June 2007 06:59 Go to next message
Originally posted by: vf_eli.hotmail.com
hello all
i'm integrating birt with a web application to render some pdf reports.
so far everything seems to work fine but i'm wondering why i don't have to
instantiate a PDFEmitterConfig and put it on the EngineConfig, i have an
HTMLEmitterConfig on my EngineConfig but i'm not sure if it needs to be
there and why it shouldn't be a PDFEmitterConfig (i used some sample code)
and because i can't even find a PDFEmitterConfig type in any of the
libraries (including itext) i'd like to know if this is the right way to
go?
thanks
Re: PDF emitter [message #242865 is a reply to message #242676] Fri, 15 June 2007 00:31 Go to previous messageGo to next message
Eli,
Depends on the version you are using 2.2 no longer uses either, but the
reason older versions did not need it is because most apps did not need
to configure fonts, which is what the old PDFEmitterConfig did. In 2.2
you can use HTMLRenderOption or PDFRenderOption. HTMLRenderOption
should work for PDF is not configuring fonts.
Jason
Eli wrote:
> hello all
> to instantiate a PDFEmitterConfig and put it on the EngineConfig, i have
> an HTMLEmitterConfig on my EngineConfig but i'm not sure if it needs to
> be there and why it shouldn't be a PDFEmitterConfig (i used some sample
> code)
> go?
> thanks
Re: PDF emitter [message #242875 is a reply to message #242865] Fri, 15 June 2007 02:57 Go to previous message
jason,
thanks for clearing that up, i was already doing that so now i know i'm
using that emitter for nothing and kick it ;)
Previous Topic:Do you have a doc like Usermanual or Developer guide please?
Next Topic:Row Visibility
Current Time: Sat Nov 22 01:22:56 EST 2025
Powered by FUDForum. Page generated in 0.03761 seconds
