Home » Archived » BIRT » Empty Data Set > Joint Data Set doesn't work ?
Empty Data Set > Joint Data Set doesn't work ? [message #242627] Thu, 14 June 2007 03:53
Originally posted by: berenice.maurel.holydis.com
Hello !
I have (Scripted) Data Set and I would like to create a Joint Data Set
with an other Scripted Data Set.
I did a test with a Data Set filled and an other empty. When I tried to
display the Joint Data Set, I have this error :
org.eclipse.birt.data.engine.impl.jointdataset.BinaryTreeROS eekerHelper$Node.access$000(BinaryTreeROSeekerHelper.java:10 3)
org.eclipse.birt.data.engine.impl.jointdataset.BinaryTreeROS eekerHelper.findNodeWithValue(BinaryTreeROSeekerHelper.java: 88)
org.eclipse.birt.data.engine.impl.jointdataset.BinaryTreeROS eekerHelper.search(BinaryTreeROSeekerHelper.java:52)
org.eclipse.birt.data.engine.impl.jointdataset.BinaryTreeRes ultObjectSeeker.getNextMatchedResultObject(BinaryTreeResultO bjectSeeker.java:104)
org.eclipse.birt.data.engine.impl.jointdataset.BaseJointData SetPopulator.next(BaseJointDataSetPopulator.java:82)
org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch (OdiAdapter.java:165)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:619)
14 juin 2007 09:31:27
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask run
GRAVE: An error happened while running the report. Cause:
2007-06-14 09:31:27,390 [ERROR]
com.holydis.quark.module.edition.EditionPDF :
org.eclipse.birt.report.engine.api.EngineException: Error happened while
running the report
I also tried to put visibility to false when Total.count() == 0, but I
have the same error. :o(
But I show this error only when I tried to display the Joint Data Set, why
? How can I avoid this situation ?
BiM
PS : When I only display the empty Data Set, it work perfectly.
PS2 : Please don't use complicate words, I'm french :o)
Previous Topic:Picking reports from database
Next Topic:Error running reports in Tomcat using WebServices datasource
Current Time: Sat Nov 15 15:25:27 EST 2025
Powered by FUDForum. Page generated in 0.03314 seconds
