Re: new version of the bridge client online can show the patients document list (Joyce Murphy @ ib [message #575182 is a reply to message #24134] |
Mon, 20 November 2006 15:54  |
Yes please, but please note that it is probably a client problem still
due to incompatibility with the new API. Using our bridge tests and
other companies who are using the tests the transaction do work.
Anyway, we will check it out.
--eishay
Dan Hale wrote:
> Eishay Smith wrote:
>> You didn't miss anything, there was a configuration problem in the
>> bridge which should be fine now.
>> Please try again.
>> --eishay
> Excellent, it finds her now. However, when I click her name and search
> for documents, I get this error:
> no patient information for JM19400814 probably an error
> I do see documents listed but I cannot download any (always get a blank
> screen). Should I create a bug report?
> -Dan
Re: new version of the bridge client online can show the patients document list (Joyce Murphy @ ib [message #575223 is a reply to message #24155] |
Mon, 20 November 2006 17:27  |
It turned to be a problem with the PHP code compatibility with the API
changes. We fixed most of teh problems, still need to work on actually
retrieving the document.
For now the version at http://ibmod235.dal-ebis.ihost.com:8080/ will
enable you to view teh document list and patient details.
To see a demo of it working use the ibmod235-all RHIO, search for Joyce
Marie Murphy of Wisconsin and get all of her documents.
--eishay
> --eishay
>>> Please try again.
>>> --eishay
>> search for documents, I get this error:
>> blank screen). Should I create a bug report?
>> -Dan
FUDForum. Page generated in 0.05797 seconds
