Home » Eclipse Projects » Plugin Development Environment (PDE) » Make plugins for legacy Java code
Make plugins for legacy Java code [message #23762] Wed, 24 September 2008 19:01 Go to next message
Hi there,
I have a big repository with one big source directory containing a big
Java package structure and all Java source files.
I need to create several Eclipse plug-ins that bundle some parts of that
source tree, WITHOUT moving files around to new locations. I may only
ADD certain config files, like manifests, plugin.xml and stuff, or
create completely new directories for eclipse projects. But I can NOT
move or copy some of the source files into new source directories within
the new Eclipse projects.
What can I do? Can I convince Eclipse somehow to adapt to our directory
structure instead of we have to adapt to Eclipse? I'm not allowed to
break the current structure as the code is also used in other contexts
than Eclipse.
Is there any way?
Hauke
Re: Make plugins for legacy Java code [message #23846 is a reply to message #23762] Thu, 25 September 2008 03:22 Go to previous messageGo to next message
Originally posted by: ekkehard.gentz-software.de
Hauke Fuhrmann schrieb:
> Hi there,
> than Eclipse.
> Is there any way?
> Cheers,
> Hauke
in this case I would use ant taks to automate copying of files to
plug-in projects. your origin files and structure will remain intact
ekke
Re: Make plugins for legacy Java code [message #24231 is a reply to message #23846] Thu, 25 September 2008 16:03 Go to previous message
You can make plugin projects the have all the metadata as if the project
actually contained the source. Then use custom callbacks to
automatically copy .java files from the main structure at build time.
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.pde.doc.user/tasks/pde_custom_callbacks.htm
-Andrew
>> Hi there,
>> than Eclipse.
>> Is there any way?
>> Cheers,
>> Hauke
> ekke
Re: Make plugins for legacy Java code [message #581333 is a reply to message #23762] Thu, 25 September 2008 03:22 Go to previous message
> Hi there,
> than Eclipse.
> Is there any way?
> Cheers,
> Hauke
ekke
Re: Make plugins for legacy Java code [message #581611 is a reply to message #23846] Thu, 25 September 2008 16:03 Go to previous message
-Andrew
>> Hi there,
>> than Eclipse.
>> Is there any way?
>> Cheers,
>> Hauke
> ekke
Previous Topic:Unable to create view: Plug-in was unable to load class
Next Topic:Eclipse 3.4 Headless Build Issues
Current Time: Thu Jul 17 19:15:41 EDT 2025
Powered by FUDForum. Page generated in 0.04251 seconds
