Problems running eclipse on NT4 [message #23747] |
Fri, 13 September 2002 07:00  |
Originally posted by: toby2000.freenet.de
Hi!
I just installed eclipse on a Win NT4 SP 6a machine. Eclipse starts but I
allways get an error because the jevaw.exe tries to call "GDIGradientFill"
in "gdi32.dll" which is not Supported by Win NT (in none of its Service
Packs).
This is only used to get the gradient fill in the TabbedDialog which is
really nice to so but not needed. So can't I turn it off somewhere maybe
some commandline switches?
Thanks in advance
Tobias
Re: Problems running eclipse on NT4 [message #24498 is a reply to message #24414] |
Mon, 16 September 2002 07:37  |
Okay, I tried it with a new Shortcut tu Eclipse but it didn' work :(
It seems there is a problem with the javaw.exe, according to the Error MSG.
It allways tries to find an entry point in the "gdi32.dll" for the
"GradientFill" Function but can't find it (since this Feature is not present
in Win NT4!).
I somehow need to tell the javaw.exe that there is no Function
"GradientFill" in "gdi32.dll".
I've tried it on a other machine quiet similar to mine and it worked fine
with no changes. I tried several SDK's (1.3.x, 1.4.0 and 1.4.1) and none of
them worked!
Anyone any Idea?
"Anders Biehl" <anders_biehl@yahoo.com> schrieb im Newsbeitrag
news:am40oo$33a$1@rogue.oti.com...
> are you explicitly pointing to the jdk1.4 i your commandline/"shortcut to
> Eclipse" ?
> something like
> "C:\Program Files\IBM\eclipse2\eclipse.exe" -vm "C:\Program
> Files\JavaSoft\j2re1.4.0\bin\javaw" -data "C:\Documents and
> Settings\Anders\My Documents\Eclipse_Workspace" -vmargs -Xmx384M
> -Anders
> "Tobias Neugebauer" <toby2000@freenet.de> wrote in message
> news:am3r2r$pa$1@rogue.oti.com...
> > I'm using Eclipse Relese 2.0 and the Java SDK 1.4
> > Any idea on this?
> > Thanks
Re: Problems running eclipse on NT4 [message #581936 is a reply to message #23747] |
Fri, 13 September 2002 10:33  |
Originally posted by: anders_biehl.yahoo.com
Hi Tobias,
I'm running Eclipse (GM3) on WinNT 4.0 SP6 just fine.
What build of Eclipse are you using ? (so I can stay away from that one).
-Anders
"Tobias" <toby2000@freenet.de> wrote in message
news:alsfj0$pi4$1@rogue.oti.com...
> Hi!
> Packs).
> Thanks in advance
> Tobias
Re: Problems running eclipse on NT4 [message #581993 is a reply to message #23747] |
Fri, 13 September 2002 19:13  |
im using eclipse 2.0.1 on NT4 SP6 no problems whatsoever.
/sanjay
> Hi!
> Packs).
> Thanks in advance
> Tobias
Re: Problems running eclipse on NT4 [message #582011 is a reply to message #23747] |
Fri, 13 September 2002 21:15  |
Tobias wrote:
> Hi!
> Packs).
> Thanks in advance
> Tobias
Perhaps you should try another jdk?
BTW, eclipse.tools is the appropriate group for these types of questions.
Stein
Re: Problems running eclipse on NT4 [message #582266 is a reply to message #24333] |
Mon, 16 September 2002 03:37  |
Eclipse" ?
something like
-Anders
> Any idea on this?
> Thanks
Re: Problems running eclipse on NT4 [message #582305 is a reply to message #24414] |
in Win NT4!).
them worked!
Anyone any Idea?
> Eclipse" ?
> something like
> -Anders
> > Any idea on this?
> > Thanks
FUDForum. Page generated in 0.07968 seconds
