Home » Eclipse Projects » Plugin Development Environment (PDE) » [pdebuild] exploding plugins
[pdebuild] exploding plugins [message #2014] Thu, 01 May 2008 15:01 Go to next message
We use pdebuild product build to create a couple of products. Recently, I
added the knopflerfish axis2 bundle into the build (into my product config
file), and it's having issues. Basically, it says that a bunch of
dependencies are missing, although they are not.
The axis2 bundle contains a bunch of other jars inside it. I tried
exploding it, but that didn't work either. It works fine in the ide, but
not from pdebuild. Any ideas what it might be?
I attached the manifest from the axis2 bundle
Paul
(Snippet from ant output)
[java]
[java] generateFeature:
[java]
[java] fetch:
[java]
[java] [eclipse.generateFeature] Some inter-plug-in dependencies have
not been satisfied.
[java] [eclipse.generateFeature] Bundle
org.knopflerfish.bundle.axis2-osgi:
[java] [eclipse.generateFeature] Unsatisfied import package
org.knopflerfish.service.axis2_0.0.0.
org.apache.xerces.jaxp_0.0.0.
edu.emory.mathcs.backport.java.util_0.0.0.
edu.emory.mathcs.backport.java.util.concurrent_0.0.0.
edu.emory.mathcs.backport.java.util.concurrent.atomic_0.0.0.
edu.emory.mathcs.backport.java.util.concurrent.helpers_0.0.0 .
edu.emory.mathcs.backport.java.util.concurrent.locks_0.0.0.
javax.mail_0.0.0.
javax.mail.event_0.0.0.
javax.mail.internet_0.0.0.
javax.mail.search_0.0.0.
javax.mail.util_0.0.0.
javax.wsdl.extensions_0.0.0.
javax.wsdl.extensions.http_0.0.0.
javax.wsdl.extensions.mime_0.0.0.
javax.wsdl.extensions.schema_0.0.0.
javax.wsdl.extensions.soap_0.0.0.
javax.wsdl.extensions.soap12_0.0.0.
javax.wsdl.factory_0.0.0.
javax.wsdl.xml_0.0.0.
org.apache.axiom.attachments_0.0.0.
org.apache.axiom.attachments.utils_0.0.0.
org.apache.axiom.om_0.0.0.
org.apache.axiom.om.impl.llom_0.0.0.
org.apache.axiom.om.util_0.0.0.
org.apache.axiom.om.xpath_0.0.0.
org.apache.axiom.soap_0.0.0.
org.apache.axis2_0.0.0.
org.apache.axis2.addressing_0.0.0.
org.apache.axis2.client_0.0.0.
org.apache.axis2.client.async_0.0.0.
org.apache.axis2.context_0.0.0.
org.apache.axis2.databinding_0.0.0.
org.apache.axis2.databinding.i18n_0.0.0.
org.apache.axis2.databinding.typemapping_0.0.0.
org.apache.axis2.databinding.types_0.0.0.
org.apache.axis2.databinding.utils_0.0.0.
org.apache.axis2.databinding.utils.reader_0.0.0.
org.apache.axis2.databinding.utils.writer_0.0.0.
org.apache.axis2.description_0.0.0.
org.apache.axis2.engine_0.0.0.
org.apache.axis2.rpc.receivers_0.0.0.
org.apache.axis2.rpc.receivers.ejb_0.0.0.
org.apache.axis2.transport_0.0.0.
org.apache.axis2.transport.http_0.0.0.
org.apache.axis2.transport.local_0.0.0.
org.apache.axis2.transport.mail_0.0.0.
org.apache.axis2.transport.nhttp_0.0.0.
org.apache.axis2.transport.tcp_0.0.0.
org.apache.axis2.util_0.0.0.
org.apache.commons.fileupload_0.0.0.
org.apache.commons.fileupload.disk_0.0.0.
org.apache.commons.fileupload.portlet_0.0.0.
org.apache.commons.fileupload.servlet_0.0.0.
org.apache.neethi_0.0.0.
org.apache.neethi.builders_0.0.0.
org.apache.neethi.builders.xml_0.0.0.
org.apache.neethi.util_0.0.0.
org.apache.xerces.parsers_0.0.0.
org.apache.xml.serialize_0.0.0.
org.apache.ws.commons.schema_0.0.0.
org.apache.ws.commons.schema.constants_0.0.0.
org.apache.ws.commons.schema.extensions_0.0.0.
org.apache.ws.commons.schema.resolver_0.0.0.
org.apache.ws.commons.schema.utils_0.0.0.
org.codehaus.annogen.generate_0.0.0.
org.codehaus.annogen.override_0.0.0.
org.codehaus.annogen.view_0.0.0.
org.codehaus.jam_0.0.0.
org.codehaus.jam.annotation_0.0.0.
[java] [java] [eclipse.generateFeature] Unsatisfied import
package org.codehaus.jam.mutable_0.0.0.
[java] BUILD FAILED
org.codehaus.jam.provider_0.0.0.
[java]
c:\eclipse\plugins\org.eclipse.pde.build_3.3.2.v20071019\scr ipts\productBuild\productBuild.xml:24:
The following error occurred while executing this line:
org.codehaus.jam.visitor_0.0.0.
[java]
c:\eclipse\plugins\org.eclipse.pde.build_3.3.2.v20071019\scr ipts\productBuild\productBuild.xml:51:
Unable to find plug-in: org.apache.xerces. Please check the error log for
more details.
org.codehaus.
jam.xml_0.0.0.
[java] [eclipse.generateFeature] Bundle org.apache.xerces:
[java] [eclipse.generateFeature] Missing required plug-in
org.apache.xml.resolver_0.0.0.
[java]
[java] Total time: 1 second
  • Attachment: MANIFEST.MF
    (Size: 8.42KB, Downloaded 304 times)
Re: [pdebuild] exploding plugins [message #3268 is a reply to message #2014] Wed, 14 May 2008 17:58 Go to previous messageGo to next message
Paul,
The bundle will need to be exploded for compilation to work, but that is
independent of the resolution errors you are getting.
The few import package statements I looked at all appear to also be
exported from that bundle. So I would guess that they aren't the
problem and they would have resolved to itself if everything else was fine.
The interesting bit is probably:
-Andrew
> Paul
> [java]
> [java]
> [java] fetch:
> [java]
> not been satisfied.
> javax.mail_0.0.0.
> [java] BUILD FAILED
> [java]
> [java]
> more details.
> org.codehaus.
> jam.xml_0.0.0.
> [java]
Re: [pdebuild] exploding plugins [message #3367 is a reply to message #3268] Fri, 16 May 2008 10:27 Go to previous message
Thanks. I figured it out a couple of weeks ago, and it turned out to be the
file name of the bundle. Once I changed the bundle's file name to match the
bundle name, it worked fine.
"Andrew Niefer" <aniefer@ca.ibm.com> wrote in message
news:482B608C.8060700@ca.ibm.com...
> Paul,
> exported from that bundle. So I would guess that they aren't the problem
> -Andrew
>> I added the knopflerfish axis2 bundle into the build (into my product
>> config file), and it's having issues. Basically, it says that a bunch of
>> Thanks,
>> Paul
>> [java]
>> [java]
>> [java] fetch:
>> [java]
>> have not been satisfied.
>> javax.mail_0.0.0.
>> [java] BUILD FAILED
>> [java]
>> [java]
>> more details.
>> org.codehaus.
>> jam.xml_0.0.0.
>> [java]
Re: [pdebuild] exploding plugins [message #566840 is a reply to message #2014] Wed, 14 May 2008 17:58 Go to previous message
Paul,
-Andrew
> Paul
> [java]
> [java]
> [java] fetch:
> [java]
> not been satisfied.
> javax.mail_0.0.0.
> [java] BUILD FAILED
> [java]
> [java]
> more details.
> org.codehaus.
> jam.xml_0.0.0.
> [java]
Re: [pdebuild] exploding plugins [message #566885 is a reply to message #3268] Fri, 16 May 2008 10:27 Go to previous message
> Paul,
> -Andrew
>> Thanks,
>> Paul
>> [java]
>> [java]
>> [java] fetch:
>> [java]
>> javax.mail_0.0.0.
>> [java] BUILD FAILED
>> [java]
>> [java]
>> more details.
>> org.codehaus.
>> jam.xml_0.0.0.
>> [java]
Previous Topic:pde/incubator/visualization update site error
Next Topic:Name of Active project
Current Time: Tue Jul 22 01:36:43 EDT 2025
Powered by FUDForum. Page generated in 0.03417 seconds
