| DTP repository [message #23603] |
Wed, 29 November 2006 23:18  |
When i try to connect to The DTP CVS repository at dev.eclipse.org
with an anonymous pserver connection i get the following error :
"Could not connect to
:pserver:anonymous@dev.eclipse.org:/home/datatools: I/O exception
occurred: Connection refused: cvs [pserver aborted]: /home/datatools: no
such repository"
Am i missing something
thanks,
chandra
| Re: DTP repository [message #23732 is a reply to message #23646] |
Thu, 30 November 2006 23:13  |
Hi Rob,
That helped. thanks a lot.
chandra
Rob Cernich wrote:
> You should be using /cvsroot/datatools as the path. This changed awhile
> back and the old /home/* locations are in the process of being phased out.
> Hope that helps,
> Rob
| Re: DTP repository [message #583233 is a reply to message #23603] |
Thu, 30 November 2006 14:58  |
Hope that helps,
Rob
| Re: DTP repository [message #583256 is a reply to message #23646] |
Hi Rob,
chandra
> Hope that helps,
> Rob
FUDForum. Page generated in 0.04006 seconds
