Pre-requisite for using EODM [message #23598] |
Fri, 17 February 2006 00:20  |
This is a multipart message in MIME format.
--=_alternative 001D8D6148257118_=
Content-Type: text/plain; charset="US-ASCII"
Although EODM compiles successfully with Eclipse 3.2.0 M4 and EMF 2.2.0
M4, the running of EODM 1.0.0 requires the following versions:
* Eclipse 3.1.0
* EMF 2.1.0 (XSD and SDO are not needed)
We only tested and support the above versions. Actually, people
are encountering problems when running EODM 1.0.0 with Eclipse 3.2.0 M4
build. Making EODM compatible with Eclipse 3.2.0 and EMF 2.2.0 will be the
target of the next version of EODM and is currently not supported in
1.0.0.
BTW, yesterday's integration build I200602161715 still has one problem
(EODM editor can not be opened in Eclipse). It is now fixed and the fix
will appear in the next build.
Content-Type: text/html; charset="US-ASCII"
<br><font size=3 face="sans-serif">Although EODM compiles successfully
with Eclipse 3.2.0 M4 and EMF 2.2.0 M4, the running of EODM 1.0.0 requires
the following versions:</font>
<br>
<br><font size=3 face="sans-serif"> *
Eclipse 3.1.0</font>
EMF 2.1.0 (XSD and SDO are not needed)</font>
<br>
<br><font size=3> We only tested and
support the above versions. Actually, people are encountering problems
when running EODM 1.0.0 with Eclipse 3.2.0 M4 build. Making EODM compatible
with Eclipse 3.2.0 and EMF 2.2.0 will be the target of the next version
of EODM and is currently not supported in 1.0.0.</font>
<br>
<br><font size=3>BTW, yesterday's integration build </font><font size=1 face="sans-serif"><b>I200602161715</b></font><font size=3>
still has one problem (EODM editor can not be opened in Eclipse). It is
now fixed and the fix will appear in the next build.</font>
--=_alternative 001D8D6148257118_=--
FUDForum. Page generated in 0.09401 seconds
