unable to find method declarations [message #23581] |
Thu, 08 May 2008 17:21  |
Search for references is working in my language editor plugin.
Neither searching for declarations (from the search dialog) nor open
declaration (from the context menu after selecting a reference in another
file) is working for me now.
Obviously, there are two possible causes of this:
a) the module that contains the method I want is not being searched
b) it is being searched but it isn't matched
I'm pretty sure that the matching works, since it works to find references.
So, I'm left to believe that the module that contains the method declaration
that I am searching for isn't being searched.
It appears that the problem may be as follows:
IExtensionPoint extPoint = this.getExtensionPoint(pluginId,
extensionPointSimpleId);
pluginId "org.eclipse.dltk.ui"
extensionPointSimpleId "queryParticipants"
This returns null:
if (extPoint == null)
return new IConfigurationElement[0];
I found org.eclipse.dltk.ui.search.IQueryParticipant
but apparently nobody implements that interface.
Do I need to implement this interface to be able to find declarations?
If so, how do I do that?
FYI - Finding declarations doesn't seem to work for Python either.
Chuck
Re: unable to find method declarations [message #23709 is a reply to message #23581] |
Fri, 09 May 2008 17:34   |
I have found out a lot more information;
but, I still don't know why searching for method declarations never works,
and searching for method references only works sometimes.
I know that for every project in your workspace, it may be indexed (by
method name declarations and/or references at least).
That indexing is done by IndexManager.rebuildIndex.
I'm not sure when that actually happens.
I tried to force index rebuilding by deleting the files in the index
directory.
However, the flag createIfMissing was usually not set.
Chuck
"Chuck Doucette" <cdoucette@vaultus.com> wrote in message
news:fvvqv3$n5b$1@build.eclipse.org...
> references.
> declaration that I am searching for isn't being searched.
> This returns null:
> Chuck
Re: unable to find method declarations [message #24142 is a reply to message #23581] |
Tue, 20 May 2008 10:21  |
Hi Chuck,
DLTK Indexer uses structure parser to report types, method, fields, etc and references into index.
The we search we use MatchLocator and MatchLocator parser to match and report AST nodes. For method declaration search
MethodLocator class are used to match for pattern.
Could you please put breakpoints to following places:enterMethod
For indexing check:
1) SourceIndexerRequestor.enterMethod(MethodInfo methodInfo)
This method will be called then we index module and report keys into index.
You could also check here for references.
Then we search using Search( For example from search dialog):
2) MatchLocatorParser.parseBodies(MethodDeclaration)
This method will be called then we we start processing of module. Module will be processed if some keys are associated
to this module, then we build index.
3) MethodLocator.match(MethodDeclaration node, MatchingNodeSet nodeSet)
This method will be called then declaration are matched from MatchLocatorParser.
Also this method will add AST node to list of search matches.
4) MatchLocator.reportMatching(ModuleDeclaration decl)
This method will locate structure model element for each of matches.
Also you could look at our Ruby, Tcl implementations.
IQueryParticipant:
This is for extensibility only. You do not need to look at them.
Python:
Does search for method declarations not work in Example?
If you have reproducible example could you please create a bug in Eclipse bug tracker.
Andrei Sobolev.
> This returns null:
> Chuck
FUDForum. Page generated in 0.05065 seconds
