Home » Eclipse Projects » GEF » [draw2D] transparent Figures always have a white background on windows
| [draw2D] transparent Figures always have a white background on windows [message #240280] |
Thu, 13 December 2007 12:10  |
Originally posted by: Gerhard.Hinterndorfer.pedrics.at
Hallo,
I have a problem implementing transparent draw2D labels on top of a swt
canvas under Windows. On the canvas I draw some other stuff: lines an
text using swt.eclipse.swt.graphics.GC.
On Linux everthing is fine: the draw2D labels are transparent :-)
But on Windows platforms (I tested it already on Win200 XP and Vista)
there I always get a white background after redraw. The size of the
white rectangle encloses exactly all the new drawn draw2D Labels.
After moving the whole Application Window out of the Desktop and moving
it in again the white rectangle disappeared.
When I switch to another application in maximized mode it disappears as
well after switching back to my RCP Application.
Does anybody have an idea?
| Re: [draw2D] transparent Figures always have a white background on windows [message #240286 is a reply to message #240280] |
Fri, 14 December 2007 14:39   |
Hallo again,
Now I prepared a Demo which shows exactly my issue explained below:
--------- Code starts here: --------------
package at.testDraw2D;
import org.eclipse.draw2d.*;
import org.eclipse.draw2d.Label;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.*;
import org.eclipse.swt.widgets.*;
public class CanvasDraw2DTest {
private static int canvasX=10;
private static int canvasY=10;
private static int canvasWidth=460;
private static int canvasHeight=300;
Canvas plotArea;
IFigure topLevelFigure;
IFigure labelFigures;
new CanvasDraw2DTest().startApplication();
private void startApplication(){
Shell shell = new Shell();
shell.setText("CanvasDraw2DTest");
shell.setSize(500, 500);
shell.open();
plotArea = new Canvas(shell, SWT.NO_REDRAW_RESIZE);
plotArea.setBounds(canvasX,canvasY,
canvasWidth,canvasHeight);
plotArea.setBackground(new
Color(org.eclipse.swt.widgets.Display.getDefault(),
180, 228, 187));
plotArea.addPaintListener
(new org.eclipse.swt.events.PaintListener() {
public void paintControl(
org.eclipse.swt.events.PaintEvent e) {
plotOnCanvas(e.gc);
LightweightSystem lws = new LightweightSystem(plotArea);
//set Draw2D Layer into transparent mode
lws.getRootFigure().setOpaque(false);
topLevelFigure = new Figure();
topLevelFigure.setForegroundColor(ColorConstants.red);
labelFigures = new Figure();
topLevelFigure.add(labelFigures);
labelFigures.setBounds(new
org.eclipse.draw2d.geometry.Rectangle(
0,0,canvasWidth,canvasHeight));
labelFigures.add(new
extLabel(canvasWidth/2,canvasHeight/2,
"Draw2D Text."));
lws.setContents(topLevelFigure);
Display display = Display.getDefault();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()){
display.sleep();
private void plotOnCanvas(GC gc){
gc.setForeground(Display.getDefault().getSystemColor(
SWT.COLOR_BLACK));
gc.drawRectangle(10,10,canvasWidth-20,canvasHeight-20);
gc.drawText ("Canvas Text.",20,20,SWT.DRAW_TRANSPARENT);
gc.drawLine(10, 10, canvasWidth-20,canvasHeight-20);
gc.drawLine(10, canvasHeight-20, canvasWidth-20,10);
class extLabel extends Label{
Label toolTip;
public extLabel(int xPos, int yPos, String text){
super();
this.setText(text);
this.setLocation(new org.eclipse.draw2d.geometry.Point(
xPos, yPos));
this.setSize(this.calculateTextSize());
toolTip = new Label("Tool Tip: "+text);
setToolTip(toolTip);
---------Code ends here -----------------
Gerhard
Gerhard H. schrieb:
> Hallo,
| Re: [draw2D] transparent Figures always have a white background on windows [message #240288 is a reply to message #240286] |
Fri, 14 December 2007 15:01   |
Originally posted by: irbull.cs.uvic.ca
I tired SWT.DOUBLE_BUFFERED on your canvas and it seems to fix things.
When using a doubled buffered canvas Draw2D doesn't try and do its own
double buffering, so therefore it is not trying to copy an image (which
must have a background) overtop of your canvas.
I don't know what will happen on MAC.
cheers,
ian
Gerhard H. wrote:
> Hallo again,
> Canvas plotArea;
> public static void main(String[] args) {
> shell.open();
> 180, 228, 187));
> plotOnCanvas(e.gc);
> "Draw2D Text."));
> display.sleep();
> SWT.COLOR_BLACK));
> Label toolTip;
> super();
> this.setText(text);
> xPos, yPos));
> Thanks
> Gerhard
> Gerhard H. schrieb:
>> Hallo,
| Re: [draw2D] transparent Figures always have a white background on windows [message #240290 is a reply to message #240288] |
Fri, 14 December 2007 16:11  |
Thanks a lot Ian, it also works in my RCP Application :-).
I already invested one day, and the solution is, as quite often, that
easy and also quite clear when I look back now
cheers,
Gerhard
> cheers,
> ian
> Gerhard H. wrote:
>> Hallo again,
>> Canvas plotArea;
>> shell.open();
>> 180, 228, 187));
>> plotOnCanvas(e.gc);
>> "Draw2D Text."));
>> display.sleep();
>> SWT.COLOR_BLACK));
>> Label toolTip;
>> super();
>> this.setText(text);
>> xPos, yPos));
>> Thanks
>> Gerhard
>> Gerhard H. schrieb:
>>> Hallo,
Current Time: Mon Nov 17 18:53:43 EST 2025
Powered by FUDForum. Page generated in 0.04154 seconds
