Home » Language IDEs » Java Development Tools (JDT) » Ant task and XML character data
Ant task and XML character data [message #240088] Wed, 24 January 2007 17:51 Go to next message
Hi All,
How can I send XML character data (text nested between the start end end
tags) to an Ant task ?
I expected the task to handle the first nested tag as text if there is
no other method (create, add, addConfigured) to handle it.
Thx.
Re: Ant task and XML character data [message #240104 is a reply to message #240088] Thu, 25 January 2007 03:33 Go to previous messageGo to next message
Laszlo Benedek wrote:
> Hi All,
> Thx.
Maybe the CDTATA tag can help you.
e.g.
<project name="squares" default="main" basedir=".">
<target name="main">
<script language="javascript"> <![CDATA[
for (i=1; i<=10; i++) {
echo = squares.createTask("echo");
echo.setMessage(i*i);
echo.perform();
]]> </script>
</target>
</project>
from http://ant.apache.org/manual/OptionalTasks/script.html
Re: Ant task and XML character data [message #240131 is a reply to message #240104] Thu, 25 January 2007 10:03 Go to previous message
>> Hi All,
>> end tags) to an Ant task ?
>> Thx.
> e.g.
> echo.perform();
> ]]> </script>
> </target>
> </project>
Philippe,
Thanks for the tip. The following works and does exactly what I need:
<target name="default">
<testTask>
<![CDATA[
<root>
<nested1>
<tag value="1">
<tag value="2">
</nested1>
<nested2>
<tag value="3">
<tag value="4">
</nested2>
</root>
</testTask>
</target>
The CDATA can be captured with addText().
Previous Topic:Help with 3.3M4 ! 'Open Type' does not show project classes
Next Topic:Remote debugging of RMI app broken in 3.3.M4 ?
Current Time: Tue Oct 28 06:54:40 EDT 2025
Powered by FUDForum. Page generated in 0.25666 seconds
