[BIRT 2.2M6] cascading parameters multiple data sets [message #239710] |
Thu, 24 May 2007 05:22  |
Originally posted by: johnww.yxcasd.org
iŽve got a problem in retrieving data from a cascading parameter group
with multiple datasets. the parameter example in eclipsepedia just works
with single datasets, an exception is thrown:
org.eclipse.birt.data.engine.core.DataException: Column binding
"SHIFT_NUMBER" does not exist.
org.eclipse.birt.data.engine.impl.ExprManagerUtil.checkColum nBindingExist(ExprManagerUtil.java:251)
org.eclipse.birt.data.engine.impl.ExprManagerUtil.checkColum nBindingExpression(ExprManagerUtil.java:209)
org.eclipse.birt.data.engine.impl.ExprManagerUtil.validateCo lumnBinding(ExprManagerUtil.java:59)
org.eclipse.birt.data.engine.impl.ExprManager.validateColumn Binding(ExprManager.java:174)
org.eclipse.birt.data.engine.impl.ServiceForQueryResults.val idateQueryColumBinding(ServiceForQueryResults.java:406)
org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:146)
org.eclipse.birt.report.engine.api.impl.GetParameterDefiniti onTask.evaluateQuery(GetParameterDefinitionTask.java:654)
so is there a possibility to retrieve the other datasets?
greets,
chris
Re: [BIRT 2.2M6] cascading parameters multiple data sets [message #239900 is a reply to message #239776] |
Fri, 25 May 2007 04:53   |
Originally posted by: johnww.asdasd.org
Hi Jason,
thx for the quick reply. iŽm running on rc0 now, the report works fine
with the new webviewer example.
but i still got the same problem in parameter extraction class:
* retrieves values from parameters controlled by a LIST_BOX or
RADIO_BUTTON
*@param task
* parameter definition task
*@param scalar
* scalar report parameter
*@param report
* report design file
*@param group
* group definition
* @return ListValues
* HashMap containing our LIST_BOX values (value, label)
private SortedMap<Object, String>
getListValues(IGetParameterDefinitionTask task, IScalarParameterDefn
scalar, IReportRunnable report, IParameterGroupDefn group){
SortedMap<Object, String> ListValues= new TreeMap<Object,
String>();
//Get report design and find default value, prompt text and data
set expression using the DE API
ReportDesignHandle reportHandle = ( ReportDesignHandle )
report.getDesignHandle( );
ScalarParameterHandle parameterHandle = ( ScalarParameterHandle )
reportHandle.findParameter( scalar.getName() );
if(scalar.getControlType() != IScalarParameterDefn.TEXT_BOX) {
//retrieve selection list for cascaded parameter
if ( parameterHandle.getContainer( ) instanceof
CascadingParameterGroupHandle ){
Collection sList = Collections.EMPTY_LIST;
CascadingParameterGroupHandle ) {
int index = parameterHandle.getContainerSlotHandle( )
.findPosn( parameterHandle );
Object[] keyValue = new Object[index];
for ( int i = 0; i < index; i++ ) {
ScalarParameterHandle handle =
(ScalarParameterHandle) ( (CascadingParameterGroupHandle)
parameterHandle.getContainer( ) ).getParameters( )
.get( i );
//Use parameter default values
keyValue[i] = handle.getDefaultValue();
String groupName = parameterHandle.getContainer(
).getName( );
task.evaluateQuery( groupName );
sList = task.getSelectionListForCascadingGroup(
groupName, keyValue );
for ( Iterator sl = sList.iterator( ); sl.hasNext( );
IParameterSelectionChoice sI =
(IParameterSelectionChoice) sl.next( );
Object value = sI.getValue( );
Object label = sI.getLabel( );
ListValues.put(value,label.toString());
}else{
Collection selectionList = task.getSelectionList(
scalar.getName() );
if ( selectionList != null ) {
for ( Iterator sliter = selectionList.iterator( );
sliter.hasNext( ); ) {
IParameterSelectionChoice selectionItem =
(IParameterSelectionChoice) sliter.next( );
Object value = selectionItem.getValue( );
Object label = selectionItem.getLabel( );
return ListValues;
my cascading parameter group:
<cascading-parameter-group name="Anlage->Schicht" id="384">
<property name="dataSet">Anlagenstruktur</property>
<property name="dataSetMode">multiple</property>
<parameters>
<scalar-parameter name="node" id="385">
<property name="valueType">dynamic</property>
<text-property name="promptText">Anlage</text-property>
<property name="allowNull">false</property>
<property name="controlType">list-box</property>
<property name="dataSetName">Anlagenstruktur</property>
<expression name="valueExpr">row["ID"]</expression>
<expression name="labelExpr">row["NAME_0"]</expression>
<property name="defaultValue">0</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="schicht" id="386">
<text-property
name="promptText">Schicht</text-property>
<property name="dataSetName">Schichten</property>
<expression
name="valueExpr">row["SHIFT_NUMBER"]</expression>
</structure>
</scalar-parameter>
</parameters>
</cascading-parameter-group>
i forgot to mention my motivation for all this:
i want to create an external filter frame just like the parameter-window
in the webviewer example, maybe theres a whole easier way to solve this
problem. some code snippets would also be great.
greets,
chris from munich
Re: [BIRT 2.2M6] cascading parameters multiple data sets [message #240207 is a reply to message #239900] |
Tue, 29 May 2007 13:59  |
Chris,
This is happening in the Viewer code as well. Can you log a bug entry
for this? It should still work BTW.
Jason
chris wrote:
> Hi Jason,
> RADIO_BUTTON
> *@param task
> *@param scalar
> *@param report
> *@param group
> * group definition
> SortedMap<Object, String> ListValues= new TreeMap<Object, String>();
> and data set expression using the DE API
> .get( i );
> ).getName( );
> sList =
> task.getSelectionListForCascadingGroup( groupName, keyValue );
> for ( Iterator sl =
> sList.iterator( ); sl.hasNext( ); ) {
> }else{
> scalar.getName() );
> return ListValues;
> <parameters>
> </structure>
> </scalar-parameter>
> <text-property name="promptText">Schicht</text-property>
> <expression
> </structure>
> </scalar-parameter>
> </parameters>
> greets,
> chris from munich
FUDForum. Page generated in 0.05710 seconds
