Home » Archived » BIRT » [BIRT 2.2M6] cascading parameters multiple data sets
[BIRT 2.2M6] cascading parameters multiple data sets [message #239710] Thu, 24 May 2007 05:22 Go to next message
Originally posted by: johnww.yxcasd.org
iŽve got a problem in retrieving data from a cascading parameter group
with multiple datasets. the parameter example in eclipsepedia just works
with single datasets, an exception is thrown:
org.eclipse.birt.data.engine.core.DataException: Column binding
"SHIFT_NUMBER" does not exist.
org.eclipse.birt.data.engine.impl.ExprManagerUtil.checkColum nBindingExist(ExprManagerUtil.java:251)
org.eclipse.birt.data.engine.impl.ExprManagerUtil.checkColum nBindingExpression(ExprManagerUtil.java:209)
org.eclipse.birt.data.engine.impl.ExprManagerUtil.validateCo lumnBinding(ExprManagerUtil.java:59)
org.eclipse.birt.data.engine.impl.ExprManager.validateColumn Binding(ExprManager.java:174)
org.eclipse.birt.data.engine.impl.ServiceForQueryResults.val idateQueryColumBinding(ServiceForQueryResults.java:406)
org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:146)
org.eclipse.birt.report.engine.api.impl.GetParameterDefiniti onTask.evaluateQuery(GetParameterDefinitionTask.java:654)
so is there a possibility to retrieve the other datasets?
greets,
chris
Re: [BIRT 2.2M6] cascading parameters multiple data sets [message #239776 is a reply to message #239710] Thu, 24 May 2007 11:12 Go to previous messageGo to next message
Chris
I just tested this in RC0 and it works. Remember to link the first
parameter in the cascade to the second data set if you want the second
data set values culled.
Jason
> at
> at
> at
> at
> at
> at
> at
> greets,
> chris
Re: [BIRT 2.2M6] cascading parameters multiple data sets [message #239900 is a reply to message #239776] Fri, 25 May 2007 04:53 Go to previous messageGo to next message
Originally posted by: johnww.asdasd.org
Hi Jason,
thx for the quick reply. iŽm running on rc0 now, the report works fine
with the new webviewer example.
but i still got the same problem in parameter extraction class:
* retrieves values from parameters controlled by a LIST_BOX or
RADIO_BUTTON
*@param task
* parameter definition task
*@param scalar
* scalar report parameter
*@param report
* report design file
*@param group
* group definition
* @return ListValues
* HashMap containing our LIST_BOX values (value, label)
private SortedMap<Object, String>
getListValues(IGetParameterDefinitionTask task, IScalarParameterDefn
scalar, IReportRunnable report, IParameterGroupDefn group){
SortedMap<Object, String> ListValues= new TreeMap<Object,
String>();
//Get report design and find default value, prompt text and data
set expression using the DE API
ReportDesignHandle reportHandle = ( ReportDesignHandle )
report.getDesignHandle( );
ScalarParameterHandle parameterHandle = ( ScalarParameterHandle )
reportHandle.findParameter( scalar.getName() );
if(scalar.getControlType() != IScalarParameterDefn.TEXT_BOX) {
//retrieve selection list for cascaded parameter
if ( parameterHandle.getContainer( ) instanceof
CascadingParameterGroupHandle ){
Collection sList = Collections.EMPTY_LIST;
CascadingParameterGroupHandle ) {
int index = parameterHandle.getContainerSlotHandle( )
.findPosn( parameterHandle );
Object[] keyValue = new Object[index];
for ( int i = 0; i < index; i++ ) {
ScalarParameterHandle handle =
(ScalarParameterHandle) ( (CascadingParameterGroupHandle)
parameterHandle.getContainer( ) ).getParameters( )
.get( i );
//Use parameter default values
keyValue[i] = handle.getDefaultValue();
String groupName = parameterHandle.getContainer(
).getName( );
task.evaluateQuery( groupName );
sList = task.getSelectionListForCascadingGroup(
groupName, keyValue );
for ( Iterator sl = sList.iterator( ); sl.hasNext( );
IParameterSelectionChoice sI =
(IParameterSelectionChoice) sl.next( );
Object value = sI.getValue( );
Object label = sI.getLabel( );
ListValues.put(value,label.toString());
}else{
Collection selectionList = task.getSelectionList(
scalar.getName() );
if ( selectionList != null ) {
for ( Iterator sliter = selectionList.iterator( );
sliter.hasNext( ); ) {
IParameterSelectionChoice selectionItem =
(IParameterSelectionChoice) sliter.next( );
Object value = selectionItem.getValue( );
Object label = selectionItem.getLabel( );
return ListValues;
my cascading parameter group:
<cascading-parameter-group name="Anlage->Schicht" id="384">
<property name="dataSet">Anlagenstruktur</property>
<property name="dataSetMode">multiple</property>
<parameters>
<scalar-parameter name="node" id="385">
<property name="valueType">dynamic</property>
<text-property name="promptText">Anlage</text-property>
<property name="allowNull">false</property>
<property name="controlType">list-box</property>
<property name="dataSetName">Anlagenstruktur</property>
<expression name="valueExpr">row["ID"]</expression>
<expression name="labelExpr">row["NAME_0"]</expression>
<property name="defaultValue">0</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="schicht" id="386">
<text-property
name="promptText">Schicht</text-property>
<property name="dataSetName">Schichten</property>
<expression
name="valueExpr">row["SHIFT_NUMBER"]</expression>
</structure>
</scalar-parameter>
</parameters>
</cascading-parameter-group>
i forgot to mention my motivation for all this:
i want to create an external filter frame just like the parameter-window
in the webviewer example, maybe theres a whole easier way to solve this
problem. some code snippets would also be great.
greets,
chris from munich
Re: [BIRT 2.2M6] cascading parameters multiple data sets [message #240207 is a reply to message #239900] Tue, 29 May 2007 13:59 Go to previous message
Chris,
This is happening in the Viewer code as well. Can you log a bug entry
for this? It should still work BTW.
Jason
chris wrote:
> Hi Jason,
> RADIO_BUTTON
> *@param task
> *@param scalar
> *@param report
> *@param group
> * group definition
> SortedMap<Object, String> ListValues= new TreeMap<Object, String>();
> and data set expression using the DE API
> .get( i );
> ).getName( );
> sList =
> task.getSelectionListForCascadingGroup( groupName, keyValue );
> for ( Iterator sl =
> sList.iterator( ); sl.hasNext( ); ) {
> }else{
> scalar.getName() );
> return ListValues;
> <parameters>
> </structure>
> </scalar-parameter>
> <text-property name="promptText">Schicht</text-property>
> <expression
> </structure>
> </scalar-parameter>
> </parameters>
> greets,
> chris from munich
Previous Topic:Scroll in a BIRT chart
Next Topic:BuildOdaFlatfile.xml
Current Time: Sat Nov 08 16:35:49 EST 2025
Powered by FUDForum. Page generated in 0.03718 seconds
