Home » Eclipse Projects » DTP » SWT Database widgets
SWT Database widgets [message #2002] |
Fri, 14 October 2005 06:43  |
I wonder if DTP project includes data aware widgets for SWT.
(ie: A Table that is associated with a JDBC resultset or a combo
displaying all values of a data column)
Bahadir
Re: SWT Database widgets [message #3422 is a reply to message #3356] |
Mon, 24 October 2005 15:54  |
David J. Orme wrote:
> Haris Peco wrote:
>> i would like test, but nested properties binding is very important for me
>> i don't accept jgoodies binding because haven't nested properties.
>> spring rcp have perfect binding - there is plan for swing independent
>> binding framework
>> i explore jface binding more
> Thanks for the feedback. Here are the issues I have uncovered with
> nested property binding. Imagine a table control that is editing a
> Customer object with an embeded Address object. Then the following must
> be true:
> 1) Validation has to cascade to the nested objects. This is tricky to
> get right.
no, i don't agree.i want validation for bind properties only
for example, if i bind properties customer.address.street then i want
validation only for street in address object
in spring rcp we declare validation for object and properties and it isn't
important where obejcts is used
it isn't perfect because i can do validation but i can't suppress property
change.for example, if field is integer and i type 'a' then spring do
validation and return error, but show 'a' in visual field - i have
workaround for this and my suggestion isn't accepted from spring rcp
> 2) Creating new objects may be tricky, depending on the back-end. Do
> you need to register the new Address object with the persistence layer,
> for example? If the Address object is reachable from multiple places in
> your object graph, how do you make sure that all the object references
> are correctly initialized.
new spring rcp handle null object properties, but i don't use it
i have base bean for form, always and when i create bean object i create
empty object for object's properties automatic with reflection (with
BeanWrapper class from spring framework) - i do it only for bind properties
for example, if i bind customer.address.street (base form bean is customer)
i create empty bean address (empty is one created with no-constructor
argument) - if i don't bind address anywhere then i don't create address
simple, i expect from binding next : when change property visual class i
want that binding framework change bean properties automatic - inverse
change (change bean properties) change visual class only with special call
(value model) - we can't bidirectional changes without listener on setter
and it isn't important (i don't want listeners in POJO - this can be
resolved with AOP, but it is unnecessary) - i change bean properties with
value model
after every changes bean properties framework do validation (i can cancel
validation) - i cancel validation when user search database - user can type
'1%' in integer field for search all rows start with '1' and i don't want
validation for this
> 3) The reverse of (2): When you're deleting a Customer object (okay, you
> probably wouldn't ever delete a customer object, but suppose that this
> is the kind of object you would delete), whose responsibility is it to
> make sure that all references to the Customer object and its Address
> object are correctly released?
> How does Spring binding handle this? How would you like it to be done?
yes, i want delete (this is database application) and i don't delete
address.
this is many-to-one relation and deleting base object don't delete nested
objects.spring rcp do nothing and it isn't important for me
all crud operation (insert,delete,update,select) are in model and it is
independent from binding
spring rcp have helper method (in form model) setFormObject and i use it for
setting new object after crud operations
spring rcp do next for me :
when i bind visual class A to bean property propA (can be nested) then
every change visual class contents (user type text or choose combo etc)
setting bean properties work with special interface only, like
ValueModel model = formModel.getValueModel("propA");
model.setValue(value);
this construction change contents visual class, but simple
customer.setPropA(value);
change only bean property
formModel.setFormObject(customer)
change all visual classes bind with bean 'customer'
framework do validation automatic, but I can call
formModel.setValidation(false)
or
formModel.validate()
settings validation : i create rules declarative with bean objects and
properties (i add automatic validation for required fields from database or
foreign and primary keys etc, too , but this is part of my framework)
Re: SWT Database widgets [message #3455 is a reply to message #3422] |
Mon, 24 October 2005 14:31  |
Thanks for your feedback.
Best,
Dave Orme
>>>binding framework
>>be true:
>>get right.
> value model
> validation for this
> address.
> or
> Thanks
Visual Editor Project lead
http://www.db4o.com -- The Open-source Java Object Database
http://xswt.sf.net -- XML-based SWT page description language
Re: SWT Database widgets [message #566940 is a reply to message #2002] |
Fri, 14 October 2005 09:59  |
Bahadir Yagan wrote:
> Bahadir
Hi Bahadir,
At the moment DTP does not, but I think that people working on the Visual
Editor (VE) project here at Eclipse have been looking at this area. I will
make them aware of this post, and perhaps they can then provide more
information.
John Graham
Eclipse Data Tools Platform Project PMC
Re: SWT Database widgets [message #566961 is a reply to message #2002] |
Fri, 14 October 2005 10:49  |
Hi Bahandir,
VE and JFace have been working together to provide data binding for
Eclipse. I expect that we will ship an early preview in either next
milestone build or the one after that.
Best,
Dave Orme
Re: SWT Database widgets [message #566992 is a reply to message #2032] |
Tue, 18 October 2005 07:17  |
Thanks. I checked-out the sources from CVS. I will try it when I got time.
I think this is a quite important feature for Eclipse and VE. I was
helping a friend to use Java, who has previous experience in .NET. It
was a bad thing to say that there is no Grid widget.
> Hi Bahandir,
> Best,
> Dave Orme
Re: SWT Database widgets [message #567011 is a reply to message #2046] |
Thu, 20 October 2005 14:56  |
Excellent.
Heads-up: we've moved over to Platform, which is where our latest work
is happening. Check out org.eclipse.jface.binding and friends. But be
advised that data binding API is still changing on nearly a daily basis
right now.
Re: Grid widget.
Look for CompositeTable and CompositeTableTest in the
org.eclipse.ve.sweet project.
I think that's what you want. It's modeless (no more click to edit),
lets you put any SWT control in any column, and is designed to be used
efficiently with the Visual Editor--something your friend with Microsoft
platform experience will appreciate.
It's designed so that it can work with any data binding framework, so
although everything is still internal API, CompositeTable isn't likely
to change much.
Dave Orme
Re: SWT Database widgets [message #567025 is a reply to message #2059] |
Thu, 20 October 2005 19:45  |
David,
i have any questions :
1) 'friends' are o.e.jface.examples.binding and o.e.jface.tests.binding
Are there yet one ?
2) Is o.e.ve.sweet deprecated ?
3) Is there nested bindings, for example , bind to person.address.street
4) Is there validation framework ?
i work rcp application with spring-rcp bindings (yes, swing control in rcp
view) and use swing because
- swt haven't good binding framework (with nested binding for ORM/hibernate
POJO)
- swing JTable (and swingx JXTable) is better than swt Table (model can be
list, header mouse event management, resizing and hiding column etc)
>> time.
> Excellent.
> right now.
Re: SWT Database widgets [message #567285 is a reply to message #2073] |
Mon, 24 October 2005 10:56  |
Haris Peco wrote:
> David,
> Are there yet one ?
That's all of them (for now).
Not exactly; just out of date. Stuff in o.e.ve.sweet is gradually being
migrated into o.e.jface.binding.
Yes, but not that way. There are validation framework issues with doing
that when you've got 1:m relationships going on.
Yes.
> POJO)
Understood. We're obviously working hard to change this situation and
would love to have folks' help testing things as soon as we have
stabilized our API...
Dave Orme
Re: SWT Database widgets [message #567309 is a reply to message #3292] |
Mon, 24 October 2005 14:41  |
>> rcp
>> ORM/hibernate POJO)
>> be list, header mouse event management, resizing and hiding column etc)
binding framework
Re: SWT Database widgets [message #567334 is a reply to message #3324] |
Mon, 24 October 2005 12:59  |
> binding framework
be true:
get right.
Best,
Dave Orme
Re: SWT Database widgets [message #567383 is a reply to message #3356] |
>> binding framework
> be true:
> get right.
value model
validation for this
address.
or
Re: SWT Database widgets [message #567410 is a reply to message #3422] |
Best,
Dave Orme
>>>binding framework
>>be true:
>>get right.
> value model
> validation for this
> address.
> or
> Thanks
Current Time: Fri Jul 25 23:15:05 EDT 2025
Powered by FUDForum. Page generated in 0.26450 seconds
