Home » Language IDEs » Java Development Tools (JDT) » Auto clean up
Auto clean up [message #239141] Thu, 21 December 2006 13:49 Go to next message
I always resort the members, format the sources before I save them. I
would also cleanup stuff like the ones in the cleanup dialog. Since I am
obsessed with the coding cleanly, sometimes sorting members give me
headaches. This is as follows,
- I start to edit a source file.
- Introduce new methods and / or fields.
- commit to cvs before sorting the members.
- later, edit the source again. This time sort the members.
- Others edit the same source. They end up with a long list of scrambled
compare editor to resolve conflict.
I think for those like me, a switch somewhere to set auto-clean up
before save would be much appreciated.
If other users/JDT committers find this idea worthwhile, I will open up
a request for enhancement in the JDT bugzilla.
Hasan Ceylan
Re: Auto clean up [message #239145 is a reply to message #239141] Thu, 21 December 2006 14:04 Go to previous messageGo to next message
Please ignore this post. JDT team seems to be one step ahead.
Hasan Ceylan wrote:
> Hello,
> Hasan Ceylan
Re: Auto clean up [message #239155 is a reply to message #239145] Fri, 22 December 2006 04:05 Go to previous messageGo to next message
Originally posted by: benno_baumgartner.ch.ibm.com
:-) we do our best. There is no sort members (yet) see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37496
Just out of interest: What other clean ups would you enable on save?
Benno
> Hasan Ceylan wrote:
>> Hello,
>> am obsessed with the coding cleanly, sometimes sorting members give me
>> scrambled compare editor to resolve conflict.
>> up a request for enhancement in the JDT bugzilla.
>> Hasan Ceylan
Re: Auto clean up [message #239169 is a reply to message #239155] Sat, 23 December 2006 05:36 Go to previous messageGo to next message
Hello Benno,
you certainly do it very well. ;)
I later noticed that but hadn't posted back again yet.
As I am a human-robot build to obey clean coding rules, I enable 'em
all. But the most valuable ones would be sort members (due to cvs diff
prob), format source, "use this for qualifier for field access", unused
imports, @override annotation, generated serial version UID...
By the way, if these are set in the preferences, do they get honored
during the preferences export/import functionality.
Because, I also force the coding styles and (now cleanup) to my team.
I would like the idea of dumping the preference in the cvs together with
these settings.
Hasan Ceylan
> Benno
>> Hasan Ceylan wrote:
>>> Hello,
>>> me headaches. This is as follows,
>>> Hasan Ceylan
Re: Auto clean up [message #239174 is a reply to message #239169] Sat, 23 December 2006 10:19 Go to previous messageGo to next message
> these settings.
If you enable them as "Project Specific" in the Project Properties
dialog, they will be stored in a .settings directory in your project,
which can be checked in along with .project and .classpath.
Hope this helps,
Eric
Re: Auto clean up [message #239218 is a reply to message #239169] Mon, 25 December 2006 03:48 Go to previous messageGo to next message
> Hello Benno,
Hi Hasan
Unfortunately we have to turn off generate SUID on save, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163797
Benno
> these settings.
> Hasan Ceylan
>> Benno
>>> Hasan Ceylan wrote:
>>>> Hello,
>>>> I would also cleanup stuff like the ones in the cleanup dialog.
>>>> Since I am obsessed with the coding cleanly, sometimes sorting
>>>> members give me headaches. This is as follows,
>>>> Hasan Ceylan
Re: Auto clean up [message #239222 is a reply to message #239174] Mon, 25 December 2006 03:51 Go to previous messageGo to next message
>> with these settings.
> Hope this helps,
> Eric
This is correct for the clean up action settings. This is not yet
possible for the save participant settings, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=168403 This enhancement is
tagged for 3.3M5
Benno
Re: Auto clean up [message #239226 is a reply to message #239218] Mon, 25 December 2006 14:36 Go to previous message
Thanks for all the comments/answers...
Previous Topic:Multiple javaw.exe?
Next Topic:How to prevent out of memory errors?
Current Time: Sun Aug 31 03:53:11 EDT 2025
Powered by FUDForum. Page generated in 0.04545 seconds
