| Re: [Newbie] Is it kosher for a plug-in to run another program? [message #239290 is a reply to message #239182] |
Thu, 06 May 2004 13:49   |
Originally posted by: kapland.uci.edu
yes, thanks. That helped a lot. would you mind answering my other question
I posted on the newsgroup if it's not to much trouble? I'll copy and paste
it here:
Hello, hope the topic doesn't make everyone avoid the post.
Anyway, I have 5 weeks to make a plug-in that reads a JAR file for
project/class/method dependencies and outputs this as a graphical call
graph. I'm doing this for a class and it will be an open source project.
Fortunately (or unfortunately) for me, I already have a separate program
that can take a JAR file as input and output the dependencies in a text
file. I also have another program that can take an input file and output it
as a graph. Neither of these programs are Eclipse Plug-Ins.
Now this is my first time working with a group of people and I don't know
much about eclipse or these other two programs I just mentioned. So I'm
wondering how will it be possible to split up this workload between multiple
people.
This is the main thing I'm wondering: Would *I* be able to make a normal
(non-Eclipse plug-in) program that does exactly what I just described above
while someone else just spends the rest of their time studying how to create
an Eclipse plug-in and at the end of the day we just convert my program into
a plug-in? Or is this a very bad way to go about it because, perhaps,
designing a regular program is complllllletely different from designing an
Eclipse plug-in?
Dan
PS: I'd also like to know if this project is conceivable :) I assume it is.
"Marko Schulz" <Marko.Schulz@gmx.de> wrote in message
news:c7dd5o$34l$1@eclipse.org...
> tieTYT wrote:
> > Hope this question isn't too annoying for people. Is it ok for an
eclipse
> > plug-in to execute another program that is not an eclipse plug-in?
> Sure. You might be able to integrate the other program better, if it was
> a plug-in, but the platform does call external programs itself too, e.g.
> when opening resources with external editors or presenting help with an
> browser.
> HTH
> marko
| Re: [Newbie] Is it kosher for a plug-in to run another program? [message #240513 is a reply to message #239290] |
Tue, 11 May 2004 15:26  |
Originally posted by: John_Arthorne.oti.com_
While it is possible to integrate a plain Java application into an
Eclipse plug-in, you will probably get much better and faster
integration by going straight for an Eclipse-specific implementation.
The Java development tools in Eclipse have extensive APIs that would
make this kind of computation quite simple. Take a look at the
implementation of the Call Hierarchy plugin in Eclipse as a place to get
started (package org.eclipse.jdt.internal.ui.callhierarchy in plugin
org.eclipse.jdt.ui).
> it here:
> people.
> Eclipse plug-in?
> Dan
> eclipse
>>browser.
>>HTH
>>marko
FUDForum. Page generated in 0.04503 seconds
