Home » Eclipse Projects » DSDP - Target Management » VxWorks TCF Agent
VxWorks TCF Agent [message #23411] Wed, 21 May 2008 04:25 Go to next message
I am new to eclipse TM project and to Vxworks as well.I am trying to build
TCF target agent for VxWorks but facing some compilation issues. Can
anybody help me what all need to done for porting TCF agent on VxWorks?
What i understood from getting started tutorial of TCF is that i have to
compile code as Kernel Module, Should i assume that agent has already been
ported on VxWorks and i donn have to make any change?
Compilation error ( I am using WindRiver Workbench v2.6):
f [ ! -d "`dirname
"VxWrkKM_Test/Debug/Objects/VxWrkKM_Test/breakpoints.o"`" ]; then mkdir -p
"`dirname "VxWrkKM_Test/Debug/Objects/VxWrkKM_Test/breakpoints.o"`";
fi;echo "building VxWrkKM_Test/Debug
/Objects/VxWrkKM_Test/breakpoints.o"; dcc -g -tX86LH:vxworks64
-W:c:,-Xclib-optim-off -Xansi -Xlocal-data-area-static-only
-Xforce-declarations -Xmake-dependency=0xd
-IC:/WindRiver/vxworks-6.4/targe
t/h -IC:/WindRiver/vxworks-6.4/target/h/wrn/coreip -DCPU=SIMNT
-DTOOL_FAMILY=diab -DTOOL=diab -D_WRS_KERNEL -o
"VxWrkKM_Test/Debug/Objects/VxWrkKM_Test/breakpoints.o" -c
"C:/WindRiver/workspace/s
plus_vxworks_bsp_1.6/splus_vxworks_bsp_1.6/VxWrkKM_Test/brea kpoints.c "
building VxWrkKM_Test/Debug/Objects/VxWrkKM_Test/breakpoints.o
" C:/WindRiver/workspace/splus_vxworks_bsp_1.6/splus_vxworks_b sp_1.6/VxWrkKM_Test\context.h ",
line 57: error (dcc:1633): parse error near 'VXDBG_BP_INFO'
line 57: warning (dcc:1503): missing semi-colon
line 134: error (dcc:1173): compiler out of sync. Probably missing ';' or
line 134: error (dcc:1056): illegal function definition
line 134: error (dcc:1633): parse error near 'vxdbg_clnt_id'
" C:/WindRiver/workspace/splus_vxworks_bsp_1.6/splus_vxworks_b sp_1.6/VxWrkKM_Test\streams.h ",
line 27: error (dcc:1082): illegal storage class
line 27: error (dcc:1117): identifier OutputStream not an argument
line 34: error (dcc:1082): illegal storage class
line 34: error (dcc:1117): identifier InputStream not an argument
line 41: error (dcc:1082): illegal storage class
line 41: error (dcc:1117): identifier write_string not an argument
line 42: error (dcc:1082): illegal storage class
line 42: error (dcc:1117): identifier write_stringz not an argument
" C:/WindRiver/workspace/splus_vxworks_bsp_1.6/splus_vxworks_b sp_1.6/VxWrkKM_Test\peer.h ",
line 22: error (dcc:1082): illegal storage class
line 22: error (dcc:1117): identifier PeerServer not an argument
line 45: error (dcc:1082): illegal storage class
line 45: error (dcc:1117): identifier peer_server_alloc not an argument
line 48: error (dcc:1082): illegal storage class
line 48: error (dcc:1117): identifier peer_server_addprop not an argument
line 51: error (dcc:1082): illegal storage class
line 51: fatal error (dcc:1553): too many errors, good bye
C:\WindRiver\vxworks-6.4\host\x86-win32\bin\make.exe: ***
[VxWrkKM_Test/Debug/Objects/VxWrkKM_Test/breakpoints.o] Error 1
Build Failed in Project 'VxWrkKM_Test' (Process Exit Value was 2):
2008-05-21 12:19:49 (Elapsed Time: 00:31)
When i analyzed the source code i found some header file incuded under
macro _WRS_KERNEL which i didnt found in the Windriver include directories
like
<private/vxdbgLibP.h> (in breakpoint.c)
Instead i found dbgLibP.h which in turn include wdb header files. Should I
use WDB library for TCF?
Karun
Re: VxWorks TCF Agent [message #23455 is a reply to message #23411] Wed, 21 May 2008 11:46 Go to previous message
Hi Karun,
Current TCF agent requires VxWorks 6.6 (Workbench 3.0).
Eugene
Re: VxWorks TCF Agent [message #574907 is a reply to message #23411] Wed, 21 May 2008 11:46 Go to previous message
Hi Karun,
Eugene
Previous Topic:VxWorks TCF Agent
Next Topic:Announcement: TM 3.0RC1 is released
Current Time: Mon Jul 21 21:44:47 EDT 2025
Powered by FUDForum. Page generated in 0.06739 seconds
