Home » Eclipse Projects » GEF » Problem with Plotting Example with Draw2D and SWT with the Java platform
Problem with Plotting Example with Draw2D and SWT with the Java platform [message #238835] Thu, 04 October 2007 01:21 Go to next message
" http://www-128.ibm.com/developerworks/java/library/os-draw2d swt"
I have downloaded the plotting example from the above line. Since
BreakCycles class is not visible i have used an alternative class
DirectedGraphLayout. Now i can able to see the view with single verticle
line and 5 dots on that. Any suggestions on this.
Hari
Re: Problem with Plotting Example with Draw2D and SWT with the Java platform [message #238952 is a reply to message #238835] Mon, 08 October 2007 09:34 Go to previous message
Infact if i could remove the import packages
org.eclipse.draw2d.graph.internal.... from DirectedGraphXYPlotter class
and make BreakCycles as public, this class works fine like showed in the
plotting example from above link, is there any other class which will do
same as BreakCycle functionality, which means A visit by BreakCycle()
touches the x and y cordinates.
Hari
Previous Topic:creating parent for already created child figure
Next Topic:Adding classes from action
Current Time: Sat Aug 30 21:13:19 EDT 2025
Powered by FUDForum. Page generated in 0.05697 seconds
