JWT checkpoint [message #23403] |
Thu, 16 November 2006 09:26  |
Originally posted by: marc.dutoo.laposte.net
Here is today's checkpoint :
board :
alain Boulzes ok
gunther ok
TODO think about the board roles' missions
proposal :
schemas sent at start of the week
friday the 24th final proposal validation
TODO write that agilPro as likely start
roadmap :
* decision process on the model
* decision process on languages and engines (includes studies, proof a
concept if needed)
* making the model flexible, singleing out extension points in it for
gram, repr, biz views
* actual impl over a chosen language *2
* 1.0 packaging
* WAM another decision process about engines
* WAM : process management API
* WAM : dummy versions of other APIs needed for a basic version
* WAM 1.0 packaging
* other tracks : still WE impls, SCOrWare contributions, AgilPro
contributions...
TODO talk to bjorn
Best regards !
Marc Dutoo
Open Wide
[Fwd: Re: XPDL generation contribution] [message #23531 is a reply to message #23403] |
Fri, 01 December 2006 04:49  |
About the Obj. Eng. XPDL mapping contribution
Thank you very much !
This helps envisioning the support of XPDL in JWT. The fact that the
export feature is implemented (as well as the import) is great news.
Best Regards
Marc Dutoo
Open Wide
Roman Zulauf wrote:
> Dear Marc
> Marc Dutoo wrote:
>> Hi Roman
>> We still plan to support XPDL in JWT, and in this light your old
Object Engineering contribution is valuable, at least for ideas or even
to enable us to have quickly a first XPDL mapping by translating to your
model. So I've got a few questions about it ^^
>> I've looked at the code in AWF_common, and it pretty much looks like
there is
>> * a complete XPDL model
> It is s more or less complete XPDL model (XPDL Version 1.0). There
are things missing like
> - ActivitySets
> - BlockActivities
> - DeclaredTypes
> - ExternalPackages
> - TypeDeclarations
>> * a complete XPDL importer (or to what extent ?)
> It is complete to the degree as stated above.
>> * but only a stub XPDL exporter : XPDLExportVisitor.java is empty
- or am I mistaken ? But I guess it shouldn't be difficult...
> That class seems to be an old leftover (sorry for that). The export
code is located here:
> ch\objeng\appl\eias\awf\common\model\exports\xpdl\XPDLExport Handler.java
> Hope that helps. If you have any more questions I'd be glad to help
you jump start on this.
> Best regards,
> Roman
FUDForum. Page generated in 0.65035 seconds
