outline view for edges [message #23341] |
Fri, 18 August 2006 11:03  |
Originally posted by: hartmut.linke.ast.iitb.fraunhofer.de
I'm working on an editor to define a water supply system. I'd like to
include all network elements into the outline view (nodes as well as
edges (e.g. pipes, channels)). Is it possible to extend the default
outline view in the desired manner?
Thanks in advance,
Hartmut
Re: outline view for edges [message #24662 is a reply to message #24544] |
Mon, 21 August 2006 09:47   |
h_linke wrote:
> Mohammed Mostafa wrote:
>> Hi;
>> Edges on the diagram surface should show up in the outline view,
>> check the Logic example
> Hi Mohammed,
> sorry, but i can't observe the desired behavoir in the Logic example.
> Probably my problem description was not precise enough. I'm only
> interested in a tree outline view. Referring to the Logic example: If i
> draw a connection between two logic elements (e. g. two gates), this
> connection should be visible as one item in the tree outline view.
> If your configuration shows this behavior, where can i define, that
> connections have to be included into the tree outline view?
> Hartmut
The Edges are displayed in the outline view when you select the OverView
mode, in tree mode we do not display connections
if you want to change this behavior check
DiagramOutlinePage , and TreeContainerEditPart
Re: outline view for edges [message #25221 is a reply to message #24662] |
Tue, 22 August 2006 04:54  |
Thanks for your advice!
Hartmut
FUDForum. Page generated in 0.05320 seconds
